Front Grill Removal!!!
Guys,
I have searched this forum and many others exhaustively. I am about to come to blows with my current OEM grill on my car in an attempt to exchange that one for some gloss black replacements. How in the world do you separate that thing from the car? I have removed the weather stripping and have the top three tabs loose, but the bottom won't bundge. Does anyone have any actual pictures of this and how to do it. This 15 min fix had cost me 2 hours thus far and no luck...any help is appreciated. Thanks
My Ride: BMW E60
Model Year: 2016
Here's what you need to do after you've done the above. Make sure the top three tabs are depressed and pushed out again. To remove, reach a hand behind the bars, get a good grip... and then yank out HARD in one motion. It literally should pop right out.
Unless someone can say or demonstrate otherwise, I have done this method a number of times, and it has always worked without any damage.
I had my buddy come over to assist and he was able to walk me through it. I guess I was a little hesistant to go yanking on the original grill for fear of breaking it, but it worked. Thanks for your help.
Location: Milky Way, Earth, N. America, CA, San Jose, 95136, Latitude N 37� 16.837, Longitude W 121� 50.461
It looks like you're all set..but in case others need a visual step-by-step on removing the grilles.. I always refer to this from the RPi website http://raceprecision.com/forums/view...6d3f8306a8d5d9
The instructions are for installing the RPi air scoop, but it gives instructions on removing the grilles first...
My Ride: 525i
this helped me alot, try to follow this right here http://www.raceprecision.com/forums/...c.php?f=7&t=17
My Ride: 2004 BMW 545i Silver,Gray, Metallic. Blk Dakota leather. Nav. Heads up disply. PDC. Pro logic 7 sound. 35% tint.
Mods. MTECH body kit. OEM trunk finisher and M5 spoiler.OEM 166 wheels. Blk and wht CF Roundels.
Orion V2 AEs. LCI taillights with Ricky effect. LED interior lights. LED license plate light. HID fogs. Smoked LED side markers. White cluster mod. Coding. RPI scoop & BMC filter. Gloss black OEM grills.CF interior trim. B&B exhaust.
OMG! How cool was that!
Popped em right off in about 30 seconds. No broken tabs.
Ready to install my RPI scoop.
Your the man Simon!
blackstarr
03-05-2015 04:54 PM
