FLASHER RELAY "WHERE IS IT"
#22
#23
Yes it is possible to speed up or slow down the speed of the flashing ...to its limits. The flashing slow speed is what it's capable of.....hopefully you don't want it slower. If that's what you want to do, it's been discussed so look on the coding forum. But as I understand it you actually have bulbs with the incorrect resistance? This can be most likely adjusted in the Neodat file but I am unsure how to do it. I am pretty sure someone in the coding forum can chime in.
#24
#25
Model Year: 2010
The fast LED blinking indicates a bulb problem, due to the system not sensing an expected bulb or bulbs. You would have to code your car to disable cold and warm checks on the bulbs you replaced with LED. The module you need to code is the LMA module.
HTML Code:
KALTUEBERWACHUNG_ KALTUEBERW_ WARMUEBERWACHUNG_ WARMUEBERW_ FEHLERMELDUNG_CC_ RFS_R, RFS_L = Reverse Light FL_R, FL_L = beam AL_R, AL_L = cornering SL_V_R, SL_V_L = parking light NSW_R, NSW_L = fog BLK_V_R, BLK_V_L = flashing front BLK_H_R, BLK_H_L = flashing back BL_M_1 = 3 Brake light KZL_R, KZL_L = plate light NSL_R, NSL_L = rear fog lamp TFL_R, TFL_L = Daylight SML = Side marker lamps BL_R, BL_R = brake light RL_BL_1_R, RL_BL_1_L = tail light brake light 1 RL_BL_2_R, RL_BL_2_L = tail light brake light 2
#27
Model Year: 2010
0,1,2,3,,,10
Ten flashes in 7 seconds. This is normal.
Here is ten flashes in 7 seconds:
http://www.youtube.com/watch?v=_51_7ygyFic
Not sure if different countries have significantly different blink rates,
seven11
06-25-2015 07:03 AM
havard@haslerud.no
01-06-2006 01:50 AM
