Engine Temperature
My Ride: Bmw 530d 2004
Originally Posted by waelfarhat' post='1081905' date='Dec 30 2009, 11:30 PM
hi all,
does anyone figured out how can we monitor the engine temperature when the car is running?
Thanks
Thanks
Instructions here.
I hope it helps!
- Antti -
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
Originally Posted by waelfarhat' post='1081905' date='Dec 30 2009, 04:30 PM
hi all,
Thanks
Thanks
- easily mounted on the engine or
- plugged into the car's data port and
- then an app for the iPhone and DROID for retrieving various data
Originally Posted by Anzafin' post='1081929' date='Dec 30 2009, 05:56 PM
You have to access the hidden menu before starting your car. Then when you start the car, the menu will stay open. Coolant temps can be seen in folder 7.
Instructions here.
I hope it helps!
- Antti -
Instructions here.
I hope it helps!
- Antti -
Thank u for the link,the procedure looks a bit complicated.i will try it soon.
Originally Posted by waelfarhat' post='1081947' date='Dec 31 2009, 12:28 AM
Hi Antti,
- Antti -
I have done it and viewed the results, 1st they are in Celsius can that be fixed and i have to hold the button down and do that every time i want to view the engine coolant temp?
My Ride: 2007 E60 LCI 523i delivery 30thNov. 2007
I found a very fast way to get to diagnostic mode. press the odometer BEFORE you insert the key on the side. Push the key in and you enter the diagnostic mode immediately.
Glowin
04-13-2015 02:42 PM
