Engine enamel DIY
Hey, didn't see DIY for any kind of engine painting so I thought I would make one just in case any one else was wanting to do the same thing. I attached the 5 images below which pretty much sums things up. I used VHT engine enamel which is extremely heat resistant.
Step 1 - Make sure you sand down everything very, very well.
Step 2 - After you get done sanding, spray and clean THOROUGHLY with a degreaser.
Step 3 - Spray about 8 inches back from the piece and go at it from different angles. Apply a thin, basic coat the first time.
Step 4 - I did 2 coats after that between intervals of about 15 mins.
Step 5 - Let sit for a few hours then good to go.
Hope this was helpful.
![Engine enamel DIY-img_0691.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/117968d1482366009t-engine-enamel-diy-img_0691.jpg)
![Engine enamel DIY-img_0714.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/117973d1482366009t-engine-enamel-diy-img_0714.jpg)
![Engine enamel DIY-img_0710.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/117969d1482366009t-engine-enamel-diy-img_0710.jpg)
![Engine enamel DIY-img_0702.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/117970d1482366009t-engine-enamel-diy-img_0702.jpg)
![Engine enamel DIY-img_0704.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/117971d1482366009t-engine-enamel-diy-img_0704.jpg)
![Engine enamel DIY-img_0696.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/117972d1482366009t-engine-enamel-diy-img_0696.jpg)
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
thesalboy
04-08-2015 09:13 AM
