emergency need help with Sprintbooster install
Originally Posted by aznunknownx' post='484828' date='Oct 22 2007, 10:27 PM
ok i've just taken it apart again and plugged it back in, i dont know what happen but the error message went away. But the yellow sign is still on (I think this is the engine oil level sign?) Is this a problem?
This is odd, but it sounds like the connection is not 100%. I know you've tried playing with it back and forth, but something seems off... I had zero issues the first time I plugged it in.
Let me ask you this...when you tried getting the OEM connection apart, did you use a lot of force? I'm wondering if you jarred something loose upon trying to take it apart, the first time around. Just a thought...
If you plug the stock connectors back together, do you get any error messages? Does the car run and feel like it did before you installed the SB? I'm just trying to work backwards and find the source for you.
Originally Posted by C's Bimmer' post='484838' date='Oct 22 2007, 08:05 PM
Does your Sprint Booster have an "A" at the end of the serial number? This would be for Automatic. I'm wondering if you have the manual version...
Yeah my SB does have the 'A' on the back of the series label, I checked this before I installed the SB on.
The error seems to have been fixed, I dont know what the cause was and all I did was plug and unplug it several times and try turning the car on each time until the error was fixed (sounds stupid, but it worked
When I tried unplugging the OEM connection apart, I made sure I was holding on to the hard plastic cover, not the cables. At first I was struggling trying to unplug it, but I managed to take it apart after a few tries. I don't think I've damaged any of the cables. The only concern that I have is probably when I pushed the SB connector to the OEM connector, I pressed on the back of the cables where the cable connect to the surface of the hard casing, for a firm lock.
This is the sign i'm talking about which still turns on when i start my car. I hope the picture helps... anyone know what this sign means?
My Ride: No mods
my car had it too. check how straight the pins are and make sure everything is tight and secure.
The weird thing is that when I press the CHECK engine button (Top left Lever of the steering wheel), it says that all Systems are Ok...
Ok I did a little research and checked the Instructions Manual and came up with this... This is the symbol which have been going off each time I start the car...
I think the Sprintbooster is conflicting with my ECU because it thinks that I'm over pressing the pedals excessively. I'm pretty sure with my installment... should I bring my car to a BMW dealer for a service check?
My Ride: E60 M5, F85 X5M
So the light goes away if you remove the SB? One of the M5 guys tried the SB on his car and when he removed it, he got a check engine light but it went away after a few hours.
I'm not sure about your case. So far, there have been members who have experienced all the lights coming on because they plugged the SB in wrong or due to a bent pin but if you've checked all that then I'm not sure what the problem could be.
If you bring it to the dealer, I would remove the SB and just tell them you saw that warning light and wanted to get it checked out. I brought my car in for service today and I removed the SB.
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Now, I'm just afraid that in the future if I try to unplug and plug it in again incase I have to bring it to the dealer for a service check, I'm going to get the same problem.
