Egr bypass on e60
Old May 16, 2011 | 12:32 PM
BallyM5's Avatar
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic, Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release, Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys im looking to fit a egr bypass on my e60 530d mine is. 2003 wandering if it would bring up any error codes once the new bypass is connected i have read on some forums that a EML would show up. As mine is one of the first e60s would this be the same or has some one got away with out any errors
Old May 17, 2011 | 02:54 AM
BallyM5's Avatar
I take it no one tried it on a 2003 e60
Old May 17, 2011 | 07:15 AM
Dav530d's Avatar
IT will bring up an error code.
Old May 17, 2011 | 08:41 AM
BallyM5's Avatar
Does the error cause any problem if the bypass is left on the car
or isit jus a error that will jus keep showing
Can this be changed by dis ncs or any of those programs
Old May 20, 2011 | 04:46 AM
madein's Avatar
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
You will get the "pump" warning light on the dashboard all the time, I was well surprise myself and of course the DDE will jump to a safe mode....
I just take the bypass back....., it is better this way and do a proper cleaning once a year.
Old May 20, 2011 | 06:43 AM
BallyM5's Avatar
What year is your e60 and which year and month was it dade?
Old Jun 6, 2011 | 03:29 AM
BallyM5's Avatar
i went ahead and have fitted one no fault has come up and i have driven the car over 100 miles so far
it feels alot more faster and better
sounds better too
lets see how it goes so far no error
Old Jun 6, 2011 | 04:36 AM
530D Lee's Avatar
My Ride: BMW
What bypass have you added? link?
Old Jun 6, 2011 | 05:12 AM
BallyM5's Avatar
its a stainless steel one from ebay
heres the item no:150609946364
didnt post the link wasnt sure if i can post the whole link here
Old Jun 6, 2011 | 09:12 PM
madein's Avatar
Model Year: 2011
That is really interested, I have use some coin only between the recirculation pipe and EGR valve and it came with fault 2 minutes after I have started my car.
I have also seen somewhere just using bolt to close only the hose for the valve, looks like I need to try again.
