e60 Sub and amp install
Old 07-04-2014, 07:08 AM
  #21
1970Gizmo's Avatar
My Ride: 2004 545i
I found the answer to my own question, if anyone is interested.
Here's the links.
Some wiring diagrams for the members
BMW Logic 7 Amplifier
Old 07-16-2014, 10:11 PM
  #22
UltimatePeter's Avatar
My Ride: 2006 530xi on Black 20's
Default PDF Instructions I made.
Hey guys, here's a PDF I made of the install I did without needing a Line Output Converter, because the low-levels are right there.
Hope this helps some people.
Old 09-16-2015, 05:24 PM
  #23
Dcolapietro's Avatar
My Ride: 08 528xi
Default Help
How do I convert the RCA wires to speaker wire. The RCA wires I have do not look like that. By that I mean that the positive and negative wire looks combined.
Old 12-27-2016, 10:39 AM
  #24
Roger Beil's Avatar
My Ride: 2007 BMW 530i E60 series
Default e60 Sub and amp install
About to take on upgrading amp/subs in 2007 530i (E60) with Logic 7 OEM amp. I have all sub speaker wire located to tap into in my 20 pin wire harness bus - BUT in the diagram attached, I don't see any remote power pin location. Slot 9 as described as Remote power in most other posts is for front left tweeter in this diagram. That slot in my harness is a yellow/green stripe wire. There is a 2nd smaller bus in my amp as well. Would Remote be in that harness.
THanks for the help.
Old 01-09-2024, 10:58 PM
  #25
PoorMansE60's Avatar
My Ride: 2009 535i xdrive
Default How big can you go before needing to upgrade the alternator?
You said you put in a 2kw amp, was it 2kw RMS? I want to put in a jp23 which is 2300 watts but I'm worried it might be to much draw. What's the biggest amp anyone's had running on stock electrical? Thanks in advance if anyone sees this. I know this thread is old AF 🤣
Awest91
09-17-2022 11:05 PM
incoherent
04-15-2015 04:48 PM
Bank$hot530
04-03-2015 07:00 PM
james69z28
03-23-2015 06:45 PM
ZeZe
10-15-2003 12:58 PM
Quick Reply: e60 Sub and amp install
