E60 / E61 M5 illuminated shift knob retrofit guide
As promised, here is the first Diy i did.
I hope it can be of some help to some people, its an easy diy that takes about 15 minutes if you have the right tools at hand.
Ofcourse i'm not a pro, so it is most likely that this mod can be done better (post your suggestions and instructions.)
As always, use at own risk!
Special thanks to nicke60gre for the help and to andy545 for informing me about nicke60gre.
Comparison between the original and the M5 shifter
Pull out the protective leather around the shifter
Remove the shift knob, easiest way to do this is by putting the shifter in 4th gear and pull the knob upwards
Remove the I-drive knob by pulling it upwards, remove the menu button by pulling it out with a soft tool (i used a screwdriver, a soft tool might be better so you wont damage the trim)
Before you start removing the trim first remove the ash tray and remove the 2 screws, then pull up the trim gently (someone on this board noted that you need super human fingers to pull this one out.. and he is right!)
Route the 2 wires below the I-drive knob and fish for it at the hole where the menu button cable comes up (you need iron nerves for this one, but its clean when its done)
The 2 outer wires of the menu button plug are the ones for the power of the led (purple/white - brown/black, the 2 outside wires), be sure to test this first.. i don't want you to Short circuit your i drive system.
I pushed the pins from the original cable together with the menu button wires into the plug and then taped them together, first the 2 wires together with the power wires and then tape around all the cables.
i'm sure there are better ways to do this, like for example soldering etc but i decided to do it with tape so i can remove the whole mod at any time, if you use cloth non-flammable tape then there should be no problem
Results afterwards
Only problem i have at the moment is that the M5 illumination is red instead of orange like the other leds, not that it looks bad but orange would have better matched the other leds.
I'm going to post pictures of the car soon, currently rebuilding it.
M5 kit, M6 style wheels, and looking for m-tech springs.
I'ts a E61, bought it in germany last week.
Results afterwards
good job! hope to see the whole pic of the car
Originally Posted by profor' post='691552' date='Oct 13 2008, 03:08 AM
Nice, so next step will be chabging orange LEDs to red ones
CertifiedOfficial
04-18-2015 12:11 AM
Mihainede85
03-11-2015 09:45 PM
