5Series.net - Forums
-   DIY: Do It Yourself (https://5series.net/forums/diy-do-yourself-14/)
-   -   E60 / E61 After market mirror install guide (https://5series.net/forums/diy-do-yourself-14/e60-e61-after-market-mirror-install-guide-110453/)
scorcher Feb 24, 2011 11:50 AM
I decided against M5 mirrors due to cost and the fact it's not an M5 (although the 530d does have more torque than a V10 now ;) )
As usual, Teddy @ SSDD sorted me out with these little fellas, and the good boys at KG had them sprayed and delivered to me.
I couldn't find a guide for fitting after market mirrors, so documented the process for your delectation!
DIY guide for fitting after market mirrors here - http://bit.ly/e61mirr
http://www.peppermintproperties.co.uk/images/acs27.jpg
Hope it is of use :)
sevenup_guy Feb 24, 2011 01:43 PM
Thank you for sharing. Great description. The new side mirrors just transforms the e61.
scorcher Feb 24, 2011 01:57 PM
Glad to be of service :)
elprettyboy14 Apr 10, 2011 02:46 PM
ok question. I was given a pair of aftermarket m5 mirrors that are autofold and come ready and all. But they weren't plug and play so i took them apart. I want to know if i can use the OEM parts as you did in this same situation.?? thanks
scorcher Apr 10, 2011 11:35 PM
I can't see why not - if you are using your existing motor and loom, you shouldn't need any recoding done.
elprettyboy14 Apr 11, 2011 06:17 AM
sounds good, ill keep you posted I plan on doing this today.. thanks again.
elprettyboy14 Apr 11, 2011 06:45 AM
also what size is the small torx tool u use I have the torx 30 and i know you stated also a small torx was wondering what size so that i can purchase it?
bruce_miranda Apr 11, 2011 07:10 AM
Nice DIY, except I was slightly taken aback that you cut the plugs of the mirrors. They are easily removed by simply removing the crimps from the plug and then rejoining the plug again.
scorcher Apr 11, 2011 07:21 AM
Aha! Wish I'd known that - never mind, I'm quite capable with a soldering iron ;)
elprettyboy14 Apr 11, 2011 05:04 PM
scorcher my question is once I disconnect the battery and complete the whole mod and re-connect the battery will my car start as usual must I do this somewhere that has a coding expert... I went to my bodyshop where I had work done on my car and they said if I disconnect the battery that once I connected it I would have to leave the car To get reprogramed?? Is this true or not I'm ready to do this mod I just don't want any surprises
