Drain plug torque spec.
Old 06-09-2009, 07:17 PM
craigm1841's Avatar
Originally Posted by cokeefe' post='906074' date='Jun 9 2009, 10:01 PM
I hope no one asks you about tightening lug nuts!
The spec's there for a reason - put your torque wrench on there and follow the spec. That's what any good tech will do.
Overtightening or dumping a load of oil when the bolt backs out is not my idea of fun.
tightening lugs to spec is unneccessary when using good judgement on the cross-tighten method.
go outside and see if your tire iron has a torque gauge on it.
Old 06-10-2009, 07:15 AM
cokeefe's Avatar
Tire iron? Is that what the guys at your tire shop use to mount wheels, or do they use a click torque wrench?
Look, do what you like with your own car, but telling other people not to worry about torque values on oil plugs and wheels is BAD ADVICE that leads to stripped out fasteners/threads or bolts backing out. There's a reason that every car manufacturer releases shop manuals that tell the tech how much torque to put on every fastener. Not a single spec is listed as "get under there and just make it tight."
Old 06-13-2009, 10:15 PM
flint's Avatar
My Ride: 2004 545i Black Graphite Metallic|Black Options:Sport Package|Premium|Cold Weather|6speed |Logic 7|Active Steering
At the dealership last week I actually asked the tech working on my oil change if he used a torque wrench to tighten the drain plug or just guessed on it. He said he just tightens it until it is "snug" then a little more.
lennox1
10-09-2015 05:13 AM
Germaniks
08-09-2015 10:46 AM
iNDOLiFE
Bluetooth & Cell Phone Forum
08-04-2015 07:06 PM
Bank$hot530
07-12-2015 04:36 PM
Syafiki
E39 Discussion
07-10-2015 06:49 AM
Quick Reply: Drain plug torque spec.
