Door panels ambiental lights
Hi ,
I need DIY for where to take power for the ambiental ledlights that are on the door panels on E60 model , I bought the door panels from a friend of mine that crash his car just for that lights, and I also bought the rear panel with the rear window roller sun blind. I need DIY for how and wher to take power for the sun blind too.
Please help
Please help
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
My Ride: BMW E60 9/04
BMW E46 / 3
The door module should have the outputs for the LED?s in the door.
I?ve retrofited the sun shade but didnt?find out how to assign it to a switch. I guess we have to pull a wire to the drivers door and buy a new door switch with the original sun shade switch?
At the moment I have assigned a seperate wireing to the shade and took power of the outlet in the trunk f.e. when car goes to the dealer. At all other time my sunshade is "up".
Ambient LED and LED in Mirrors outside I want too!!!! So please, give us a DIY.
to replace door LED light, door panel should be removed. Correct me if I'm wrong.
I found this out during the process of removing door panel to install door speakers.
Please search on this forum for removing door panel.
I have that original switch on the driver door panel coz I bought the door panel too from the crushed car , but like you said we need a DIY to see witch wire is controling the sun shade of that 4 wires that are on the door panel command module where the buttons are.
Yes, the door panel should be removed I know how to do that .
TexaZ3
05-06-2015 09:54 AM
