DIY SMG Clutch Replacemnet
My Ride: 2005 545/SMG Sport Package HUD Logic 7 Bluetooth NAV Cold Weather Package
Has anyone performed a DIY clutch on an SMG equipped e60? So I need the GT-1 software to bleed the clutch actuator?
replacing the clutch is the same as a regular clutch on any other vehicle. the only exception is the hydraulic shift actuator which is attached to the side. As long as you dont open any of the hydraulic lines, you should be fine. The actuator basically replaces the slave cylinder on a normal cutch transmission.
ye i've seen my car with the transmission dropped. looks just like any other tranny. make sure u pull the battery though there are alot of sensor connected to the clutch/transmission case
Unfortunately I didn't take any pics but I repaired everything. While it was out I replaced the clutch, water pump, engine mounts, spark plug tubes, cam cover gasket, valve cover gaskets and the oil pressure switch. Right now I'm trying figure out why I have an passenger SRS fault message. It wasn't there prior to removal of the engine. I haven't driven it yet but I have seen the dreaded gearbox fault message yet.
My Ride: 2005 545i Sport 6sp,
