DIY for replacing mirrors on a post 09/05 pre LCI
My Ride: 06 550i
Model Year: 06
First the things you'll need for this:
T30 driver to unscrew the mirrors
A flathead wrapped in masking tape to pry the door off and unscrew the cover for the battery in the trunk
A small socket to unscrew the battery connection
A plastic bag to hold the battery terminal
[attachment=150859:IMG_0382 - Copy.JPG]
The two circled area are where the 2 screws are located that need to be loosened. You can then pull it away using the little opening on the bottom of it.
[attachment=150860:IMG_0383 - Copy.JPG]
Use the socket wrench to disconnect the terminal. Make sure to not drop the nut or bolt down into the area next to the battery.
[attachment=150861:IMG_0384 - Copy.JPG]
550iwa
03-27-2015 06:45 AM
andymax
03-13-2015 10:51 AM
bapeforceone
03-11-2015 04:18 PM
