DIY: Rear Sway Bar
Old Aug 12, 2010 | 06:57 PM
525iEnjoy's Avatar
Tools you'll need:
16mm wrench
T30 torx head socket I used 1/4 inch drive ratchet
3/8 drive ratchet
3/8 socket 14mm
14mm wrench
Grease
spare jack stand (optional)
Jack the car up and support it with stands or use Rhino Ramps. I used Rhino ramps so. Be safe though.
One car is up, you wanna loosen the endlinks first using the closed end of the 16mm wrench over the nut, then take the T30 torx head and hold the bolt from spinning, then ratchet the nut off the bolt, do that on both sides. Next take your 14mm socket and break loose the nut on all 4 bushing brackets, then take your 14mm wrench and feed thru to the top of the bolts holding the brackets on and once in place ratchet the nut off the bolts. Now you will take the bolts out from the top, Caution that the bar might fall once all nuts are taken off in this case use a spare jack stand and place it underneath the sway bar. Mine was seized in place so it didnt fall but you never know. A few tuggs may be needed to remove.
Once off, look at the location off the stock mounts. The new sway bar will come with bushings so take the grease and apply a liberal amount and wipe some inside the bushing and then put a little on the sway bar where bushing will sit. It will take some finessing to get the new bushings on the bar, slide the bushing close to wear stock is then push straps over the bushing after that reverse the install. I am sure I missed something so please ask
You can see stock vs Dinan 21mm!!!
Old Aug 12, 2010 | 07:05 PM
e6t.lab.rat's Avatar
Nice DIY! That Dinan swaybar WILL make a noticeable improvement I'm sure
Old Aug 13, 2010 | 05:11 AM
jgt's Avatar
jgt
My Ride: E60
Engine: N52
Great job posting the DIY!
This is an easy DIY mod with a definite performance improvement thats quite frankly overlooked.
I swapped out my front and rear sway bars for the M6 convertible bars.
29mm in the front
20mm in the rear
Old Aug 13, 2010 | 10:57 AM
Howitzer's Avatar
I replaced front and rear sway bars 2 weeks ago and the difference is so amazing. Its a great mod if you love turning sharp or changing lanes like you're in a go kart!
Old Apr 24, 2011 | 07:47 AM
Bimmer5project's Avatar
My Ride: Sapphire Black 07 530i non-sport 7000k Angel Eyes 6000k HID Xenon adaptive turn Head lamps and Fogs, Clear LED Turn Signals front/back and side markers. Clear bright license plate lamp. Full interior lighting upgrade. Coding: daytime angel eyes, auto windows up, and digital speedometer. (Thanks to John at Motorcepts.com) OEM Tinted LCI Tail lights (Thanks to David at http://www.luxmotorwerks.com Oem Mtec rear bumper with diffuser and M5trunk finisher Debadged! The best paint work! (Thanks to Desimone BMW) 20x8.5 +18 20x10 +25 Concept One RS-8 Black Machined Chrome Lip V6.1 cables (Thanks to Bruce Miranda) Nitto Invo tires 285x30 R20 - 245x35 R20 Discounttire.com Vac Motorsports ecu chip upgrade, and fender roll http://vacmotorsports.com/ wish list: Rieger Front bumper Hamann side skirts Custom quad exhaust Rpi Ram air intake scoop M5 SMG shift knob KW Variant 3 suspension Brembo Big Brake kit LCI Heads Tints BMW M5
What brand makes the best sway bars?
kongse
Jul 17, 2015 03:29 PM
Daniel_gnt
Apr 20, 2015 06:37 PM
Stranger12
Apr 5, 2015 10:42 AM
joeekrub
Mar 25, 2015 07:00 AM
