DIY : Mtech Front Bumper Removal
Model Year: 2005
Engine: 545i
All -
Here is my DIY to remove the mtech front bumper. The reason I decided to create this was because I never found complete, common sense directions on the forum. Yeah, I read the TIS documents but didnt feel like this went into enough detail. Here is a nice, step by step DIY to help you remove the bumper with pictures. Hopefully this will help someone down the road.
I left the DIY in word format as I didnt have the capabilities to convert into PDF.
This was in reference to my original topic: http://forums.5serie...9&#entry1097659
good job - nice instructions
![](https://5series.net/forums/public/style_emoticons/default/twoup.gif)
more exists - check my sig
![](https://5series.net/forums/public/style_emoticons/default/original.gif)
My Ride: 08 535xiT
Just wanted to add a little more information. Those three screws on either end under the headlight do not need to be removed. If you look closely at the parts, those three screws are holding a plastic part onto the fender that basically clamps the bumper on. The first clip you can see and with a thin blade screwdriver you can loosen it and remove it. The next two you can't see, but there is a hole about the size of a hole punch in the metal above each tab, push your screwdriver through that and you can pull the bumper out without having to remove that plastic piece.
I removed the bumper so that I could replace the washer fluid pumps that were leaking and learned about this.
chadillac2000
42
09-13-2017 11:15 AM
blackstarr
03-05-2015 04:54 PM
