DIY LCI taillight retrofit
I don?t think this has been done on this forum so here goes: -
To start off this is one of the easiest DIY?s I?ve done and thanks to Bruce Miranda for the cables.
Parts required:-
LCI taillights
Bruce Miranda?s Adapter cables
![DIY LCI taillight retrofit-dsc02164.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45264d1482365952t-diy-lci-taillight-retrofit-dsc02164.jpg)
and double sided tape or tie straps
Tools used, mini ratchet with 8mm socket with extension, flat head screwdriver and a brick (For the Brake pedal, I was on my own).
Instructions:-
Remove the trunk floor carpet
Remove all 4 black clips whick hold the truck trim with screwdriver (Rotate 90 degrees the pull out).
![DIY LCI taillight retrofit-dsc02150.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45260d1482365952t-diy-lci-taillight-retrofit-dsc02150.jpg)
Remove trunk trim panels as in the picture
![DIY LCI taillight retrofit-dsc02152.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45261d1482365952t-diy-lci-taillight-retrofit-dsc02152.jpg)
Each taillight is fixed with 4 x 8mm nuts (1 is a locking nut) remove these. Unplug the taillights and remove the units. (Remember take note of the gap around the lights before you remove)
![DIY LCI taillight retrofit-dsc02158.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45262d1482365952t-diy-lci-taillight-retrofit-dsc02158.jpg)
Insert the new units and loosely fit all the nuts, align the taillights and tighten the standard nuts first. Use the locking nut for the final alignment.
Plug in Bruce?s adaptor cables and fix them with double sided tape as in the pictures (I also used tie straps but are not pictured).
![DIY LCI taillight retrofit-dsc02184.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45271d1482365952t-diy-lci-taillight-retrofit-dsc02184.jpg)
![DIY LCI taillight retrofit-dsc02189.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45272d1482365952t-diy-lci-taillight-retrofit-dsc02189.jpg)
Check that the lights are working correctly then finally build all the truck trims back up and lay the carpet.
It's as easy as that!
Enjoy Before and after pics: -
Before:-
![DIY LCI taillight retrofit-dsc02138.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45257d1482365952t-diy-lci-taillight-retrofit-dsc02138.jpg)
![DIY LCI taillight retrofit-dsc02146.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45258d1482365952t-diy-lci-taillight-retrofit-dsc02146.jpg)
![DIY LCI taillight retrofit-dsc02149.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45259d1482365952t-diy-lci-taillight-retrofit-dsc02149.jpg)
After:-
![DIY LCI taillight retrofit-dsc02174.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45265d1482365952t-diy-lci-taillight-retrofit-dsc02174.jpg)
![DIY LCI taillight retrofit-dsc02175.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45266d1482365952t-diy-lci-taillight-retrofit-dsc02175.jpg)
![DIY LCI taillight retrofit-dsc02176.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45267d1482365952t-diy-lci-taillight-retrofit-dsc02176.jpg)
![DIY LCI taillight retrofit-dsc02177.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45268d1482365952t-diy-lci-taillight-retrofit-dsc02177.jpg)
![DIY LCI taillight retrofit-dsc02180.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45269d1482365952t-diy-lci-taillight-retrofit-dsc02180.jpg)
![DIY LCI taillight retrofit-dsc02183.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45270d1482365952t-diy-lci-taillight-retrofit-dsc02183.jpg)
![DIY LCI taillight retrofit-dsc02191.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45273d1482365952t-diy-lci-taillight-retrofit-dsc02191.jpg)
![DIY LCI taillight retrofit-dsc02194.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45274d1482365952t-diy-lci-taillight-retrofit-dsc02194.jpg)
Parts required:-
LCI taillights
![DIY LCI taillight retrofit-dsc02162.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45263d1482365952t-diy-lci-taillight-retrofit-dsc02162.jpg)
Instructions:-
Before:-
After:-
![DIY LCI taillight retrofit-dsc02195.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/45275d1482365952t-diy-lci-taillight-retrofit-dsc02195.jpg)
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Make me so tempting mate!! Has been thinking to get this for ages but the cost of the kit has putting me off.
(No offence in here bruce, i know you've spent loads of time and money to get this thing work, and its a great kit!)
I'll be interested if there is a group buy for the retrofit kit. Anyone interested?
And thanks for the write up Dav!!!!
My Ride: 2005 545i E60 Orient Blau Metallic
Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
Count me in as interested for a group buy. I think it's a great cable set Bruce but a too much moolah up front for my taste.....
BTW -- Rover Active is selling the LCI lights on eBay for 599 USD with a retrofit kit that says wil work without error messages. Does anyone know about this offer/tried it? Bruce, is this your kit he is selling?
Also as mentioned I can get people a discount for exactly those lights from RoverActive if you get my cables. I don't think I can offer a discount on the cables themselves. It's simply not worth it for me because its far too much work at the moment and I just do this in my spare time. With a 4 month old baby and a full time job there's hardly any of that to be found
Just wait, someone is bound to copy my kit soon and manufacture this at less than half the price.
