DIY: How to replace the spark plugs on your V8
Old 08-26-2009, 07:11 PM
Curmudgeon's Avatar
My Ride: 2005 545i, Silber-grau/grau. Vanilla flavored except for cold WX pkg.
Great DIY! That's a keeper for when I need to do it.
Old 08-27-2009, 05:36 PM
suthurnbimmur's Avatar
My Ride: 2004 BMW 545i
EXCELLENT write up, next thing to do on my car...................thanks.
Old 08-27-2009, 05:45 PM
DRANGED's Avatar
+1 Thank you very much for the write up!!
Old 09-08-2009, 05:27 PM
bmwroger1's Avatar
My Ride: 2004 BMW 545I M sport suspension Active Steering M sport interior Navi Low ride sports
i have a 2004 545I and i tried to remove that plug closest to the firewall on the drivers side.....even when removing the bracket for the power wire....i still could not remove that coil... are you sure that is all you have to move out of the way? i got very frusterated and decided to leave that one in....but i have to change it...but i will try to remove it again...since that it the only solution..
Old 09-10-2009, 05:18 PM
billeul's Avatar
Great DYI writeup, thank you. For others with older 545i's, mine is a 12/03, do not spend any time looking for the coil hold down clips, there are none. Just remove the connector and pull the coil tube out.
Old 09-10-2009, 09:55 PM
wees75's Avatar
My Ride: BMW 550i 2007 M-Kit installed- 367 BHP Sapphire black, comfort seats, comfort access, HUD, Professional Nav, Logic 7.
Originally Posted by cokeefe' post='988022' date='Aug 25 2009, 07:03 PM
This is a medium-difficulty project, probably about a 3 on a scale of 10, where 1 is putting air in your tires and 10 is doing an engine rebuild using only a set of Harbor Freight adjustable wrenches and a box of toothpicks, with ?assistance? from my two year old son.
Continued next post
Thanks for sharing... Did you notice a significant change in performance afterwards?
Old 09-11-2009, 08:57 AM
chosenone357's Avatar
My Ride: 2006 550i, Premium Package, Navigation, Comfort Access, L7 Sound 2004 FX35, Sports Package, Stillen CAI
Excellent write-up man....I was just about to ask my mechanic to change mine out for me, but decided to search the forum....good stuff
Old 09-25-2009, 07:03 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
first off, a correction.....you need a 3/16 12 pt socket to remove the hold-downs.
i found it hard to pull the coils off, but i used a screwdriver as leverage, combined with pulling on them, and it made the coils come off a lot easier.
DIY: How to replace the spark plugs on your V8-spark.jpg
my plugs had 77k miles on them, and probably could have gone for a lot longer. the old plug tips were worn down slightly.
the original plugs were bosch, and i replaced them with the ngk 4294. they look similar.
DIY: How to replace the spark plugs on your V8-spark2.jpg
DIY: How to replace the spark plugs on your V8-spark3.jpg
Old 09-25-2009, 08:01 PM
cokeefe's Avatar
Good catch. I mistyped the size on my notes and then repeated it here. Dunno why, but I can't edit the original post now....
Once I twisted the coils in place a little, I didn't need leverage, but my car has 30K fewer miles...it makes sense that the coils will need more persuasion the longer they've sat in there. And...nice granite workbench.
Not really. It "seemed" to make drive-off from stop signs and lights a little easier (I have a 6-speed manual) but that may or may not be psychological. Mileage stayed the same.
Old 09-26-2009, 10:26 PM
SIC FKR's Avatar
My Ride: Stock for now
Thanks for all the pics and tips. I plan to install my this winter.
Quick Reply: DIY: How to replace the spark plugs on your V8
