DIY: ECU Removal
My Ride: Carbon Black 545i
Here is a DIY for the ECU removal
1. Box located on passenger side.
2. Locate the sensor and remove
3. Remove the rubber cushion lining.
4. Remove center lock mount.
5. Unlock using a 13mm socket , then remove plastic panel.
6. It should look like this. Then unlock 2 more bolts to remove cover.
7. You can use a torque wrench, but a flat head will work too (I think its alil faster), and unscrew each bolt.
8. After you remove all the screws and lift up the panel. The ECU will be located at the very top.
Originally Posted by stel_i79' post='594452' date='Jun 3 2008, 11:59 AM
i have a 2006-530i -base model how many HP I CAN GAIN?
WHERE to send the ecu ?
thx.steli
thx.steli
545, 550= 20 hp, 25 tq gain
http://forums.e60.net/index.php?showtopic=54240
There's a big sale going on right now don't miss it.
thx.steli
thx.steli
Originally Posted by NeRwEEzy' post='594474' date='Jun 3 2008, 01:24 PM
send a pm to john@eurorev
http://forums.e60.net/index.php?showtopic=54379
PelicanParts.com
07-09-2015 01:07 PM
