DIY E61 Lowering guide
My Ride: E61 sold nice E91 335i Sport Touring now
After reading Tiago's post I realised this was possible without going to a dealer.
DISCLAIMER: Undertake any of this at your own risk. This is just the method I used and thought I'd share it with you.
Took some before and after photo's of the ride height, so lets start with them.
Before
After
Started by taking the rear wheels off and raising the car high enough to get under it comfortably.
Then locate the sensors. I will go through and show photo's of the RHS one but the LHS one is virtually the same so no need to show both!
RHS sensor from a distance to help you find it. Its circled with a very shaky blue ring!
A close up. 10mm nut circled in blue needs to be removed and then this link is disconnected from the lever arm. This allows access to both allen/hex bolts holding the sensor.
Once the link is disconnected you can loosen the bolt with the blue arrow and remove the top one.
Rotate the switch in the direction seen below. The red arrow is where I decided to move it. The blue is where it was originally. On this side you could use a large washer to help secure the bolt to the bracket. The other side I have left with just one bolt but may make something up to hold it.
Make sure the bolts are tight. Loctite would be an idea particularly on the LHS one if you leave it with one bolt securing it!
Refit the link.
Fit the wheels and lower the car back down. I then started the car up and eventually the car settled down into its new position. Probably an idea to recheck the sensors are secure after a few days. If they move then I'm sure you'll notice the rear sitting higher or lower
Before
After
Refit the link.
My Ride: 2008 550i manual
Engine: V8
Nice! Great post, but i dont think I would do that Here in NYC the Roads are a bit nasty and we need that space between the wheel well ad the tire so no scraps or even worse
My Ride: 2004 545i SGM Steptronic Dinan CAI Dinan TB GTech Pro RR
[quote name='chesney72' date='Nov 14 2008, 02:03 PM' post='721243']
I tried to find the post you referred to (Tiago's) but was unsuccessful. I take it this is a way of 'dummying' the system to lower (or raise) it's static position? Any additional insight owuld be appreciated....I've swapped springs twice on my 545 to get the correct ride height and would still like to drop the rear another inch or so. What's the downside of doing this?
The ride quality seems to be the same as before. Supose it would be bad if you went too low.
By rotating the switch it fools the car into thinking its sitting higher than before and so it lowers further before it gets the signal that it is at the right height.
It was Tiago's post that mentioned to rotate the switch. My DIY is just a full write up which hopefully explains it better.
Originally Posted by myfiveserie1818' post='724844' date='Nov 19 2008, 06:00 AM
wow very nice write up!
Fitting heated seats to the car as we speak.......well inserting the pads into the existing seats. Watch this space for another DIY
Originally Posted by mikey k' post='727902' date='Nov 21 2008, 09:22 PM
So does this lower the whole car or just the rear?
