BMW H8 bulb connector / plug
Old 01-30-2013, 05:56 PM
vkhong's Avatar
Model Year: 2010
Default BMW H8 bulb connector / plug
This is the BMW socket / female connector for the H8 light bulb. I broke the clip on the left side of the picture.
A couple of questions:
1) What is the part number of this connector? I checked RealOEM 61 15 Diverse Plugs and Connectors and do not see this H8 connector.
2) Can the pins be removed with a tool and inserted into the new connector? There appears to be some play / movement of the pins in the connector when I pushed the wires.
I had just parked the car (engine bay and headlight assembly still warm) and removed the connector and caused the clip to break. It is just below freezing temperature here. I suppose the plastic cool off very quickly.
I could use an aftermarket H8 connector but would like to try the OE connector first. Here are a couple of water-resistant aftermarket H8 connectors:
Old 02-07-2013, 04:26 PM
vkhong's Avatar
Model Year: 2010
For those willing to cut and splice, aftermarket H8 bulb socket connector / housing are readily available, eg:
Dorman H8 / H11 blub headlight socket part 84783
(select image for more informaion)
Old 02-07-2013, 04:51 PM
vkhong's Avatar
Model Year: 2010
The BMW / OE H8 light bulb socket connector can be disassembled.
There is one compression metal tab on each side of the pin and the top of the socket housing must be lifted open for the pins to be pulled back from the socket. A friend helped me figure this out.
Old 02-07-2013, 05:05 PM
vkhong's Avatar
Model Year: 2010
Here is the current BMW / OE H8 light bulb socket housing / connector.
BMW part 61136907388
(Select image for more information):
It comes with water-resistant / weatherized contacts:
BMW part 61130007272
The original non-weatherized contacts from the vehicle should fit fine into the BMW / OE connector.
Old 02-11-2018, 12:56 PM
vkhong's Avatar
Model Year: 2010
This may help identify the OE connector, it is actually the BMW H8 bulb connector. The gray connector with the orange and yellow wire:
The current BMW H8 bulb connector is part 61132360041.
A generic H8 bulb connector or repair kit should also work.
TroyE60
05-30-2019 05:01 PM
Kasmo
05-07-2019 03:30 AM
JonathonK
03-27-2015 08:13 AM
joeekrub
03-27-2015 04:04 AM
reckamech
09-08-2003 01:24 PM
Quick Reply: BMW H8 bulb connector / plug
