DIY E60/E61 Rear Upper Windshield Moulding Seal Install
14 Attachment(s)
What good is it to own a luxury ride that looks like crap.. So, hands on B)
Got the rubber at Amazon from BMW it self for $36.00. Shipping is free if you have Prime, if not you fucked. I was quoted like $78.00 at the town stealership, about $59.00 if buyin' from a shop. Install time is anywhere between 30 - 90 min depending on your skill level. Tools used.. Attachment 153339 Ahhhh! What's the tape for? Attachment 153340 Or you don't need tape and scratch the shit out of everything, your call :twoup: De-install/install process: 1. Open trunk and pry out from the corner slowly. Attachment 153341 Attachment 153342 Attachment 153343 Attachment 153344 2. At this point you can just use your hand or your hook if you are a pirate to pull it out. Slow down when you hit the corner or you will snap the rubber and have to start all over again. Attachment 153345 3. Once it's all out, spray Windex to clean the edge of the glass and the drain gutter where the seal goes. So, from this: Attachment 153346 To this: Attachment 153347 Attachment 153348 4. Once cleaned up, align the seal from both top corners and apply pressure inwards with your fingers or if thick fingers with anything you want to use that wont mess up the seal and put the condom in. Attachment 153349 Attachment 153350 5. After the seal it's on, reapply pressure again all around for a tidy seal. Attachment 153351 When the job is completed this is what it should look like, if it doesn't ahhh you probably not ready to work on your own car just yet :evil: Attachment 153352 *** I didn't use any silicone , but it's your car. You CAN put some on or not. It's up to you. The windshield its sealed already and the seal is tight and well designed. *** Oh, and for those that have said that the stealership charges for windshield removal for this job.. Ay ay ay amigo :rolleyes: Cheers! L. |
| All times are GMT -8. The time now is 03:29 AM. |
