DIY: Cleaning VANOS Solenoids
My Ride: 2007 525xi
Hey,
So.. no luck with the oil change. My codes have also come back and trigger a Check Engine light every so often.
I'm going to give them another cleaning (this time leaving them in fuel for longer). I'll do that once it gets not-freaking-cold outside. Right now I can't be outside for more than 10 mins without gloves and have my fingers not feel like they're about to fall off.
If all else fails, I'm going to see about acquiring a new set of solenoides. They're unfortunately not that cheap. I might see if my crappy aftermarket warranty can cover them though.
Hey,
Thanks for the directions and pictures.
Brian
Just found this thread (http://www.e90post.com/forums/showth...ighlight=vanos). Might be helpful. Claims that compressed air to clean them might do the trick. I know you mentioned that but didn't see if you actually did that or not.
My Ride: 2007 525xi
Just found this thread (http://www.e90post.c...highlight=vanos). Might be helpful. Claims that compressed air to clean them might do the trick. I know you mentioned that but didn't see if you actually did that or not.
Good point though - I didn't try compressed air.. mostly because I didn't have one of those cans on me at the time. It'll be on my to-do list for VANOS solenoid cleaning round #2.
Someone on one of the e90 forums (I forget which one) also mentioned that he was able to "test" the solenoids by hooking up a 12v DC source to them. When given power, a little rod should stick out the end a a certain distance. If I recall correctly, when he did the same test on a new solenoid, he found out the old one was actually only coming out half the distance it was supposed to.
As for the gaskets - when I took the solenoids out, I didn't notice anything that'd prevent them from being re-used. They felt like hard plastic rings, and should be re-useable without any issues.
So I performed the "cleaning" last week but the SES light came back on just yesterday. I went back to get the codes pulled and the same P0012 came up, but this time instead of the P1554, I got a P1553 instead. I did swap solenoids so I don't know if that's why I get a 1553 this time, but what concerns me is the P0012 is the same. I was hoping that I'd get a different code since I swapped, but now I'm concerned that even if I replace both that it won't fix the problem.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Just a quick question did you clear all the fault codes and then these new ones appeared? You sure it's not a camshaft position sensor or just bad gas? Give some stats.
HOWEVER, about a month ago the SES light came back and stayed on despite another fillup with BP 93. This time I decided to get the codes pulled. P0012 and P1554 were pulled and I found myself here. (and other threads) Pulled the solenoids, cleaned them and swapped them. SES was off for about a week. Light was on for 1 day and then off again. Had the codes pulled again and this time P0012 and P1553. Now, I didn't ask the tech to clear the codes, nor did I see if he did so one of those might be a past code from before. (Although they didn't list the P1554 as before)
Seeing that the P0012 was the same but P1553 was different, I'm leaning toward a sensor being out more than anything. The light hasn't been on for a few days now. I'm confused though as to which sensor it would be as P1553 seems for 'A' (intake?) and P1554 for 'B' (exhaust?). Right?
Bro you need to re-initialize the solenoids on the car and you can only do this with BMW tools. INPA would do or you can use Progman. INPA is very quick, would take like 15 seconds. Have your guy at least clear the codes. That will not re-initialize the solendoids but you can see which is an old code and what is new.
P15 is the exhaust, 12 is the intake.
I'm telling you I bet it's the camshaft position sensor and this is messing up your timing. Are you getting rough idle or car is bogging down or sometimes randomly shut off?
You can pay dealer to do it or you can do it yourself. As of right now it's not something big unless your car is shutting off randomly....example I had a 325CI and the car would run fine and then all of a sudden at a red light or going into drive from reverse it would die. I had enough when I was trying to get out of my subdivision on a busy road and I was crossing to the median and the car died...if it weren't for my batman like reflexes I may not be here bro. So get yourself some tools and you'll know exactly what it is and get the part from the dealer and then replace it in 20 min. done deal.
exhaust camshaft position sensor A/B... give me last 7 of your vin
is that yours?
http://realoem.com/b...736&hg=11&fg=15
03 Sensor, camshaft 213627525014 $95.3
04 O-ring17X3 212141748398 $1.20
is that yours?
It's an E60 530xi - Vin #7CU27308.
I wouldn't really say the car is rough and it definitely doesn't shut off. Sometimes it feels like its bogged down, but I also just moved to GA where there are more hills than I'm used to so I can't tell if its the car or the hills. The SES is off right now and has been off since Sat. and it seems to be driving fine.
If I replace the sensor, do I still need to get the solenoids re-initialized?
