DIY for changing oil?
My Ride: 2006 525
since many of us new owners are interested in changing the oil before the first scheduled maintenance, can anyone post a DIY (with pics would be awesome)
many thanks
many thanks
My Ride: E60 530i
Engine: M54
many thanks
many thanks
[snapback]148234[/snapback]
My Ride: E60 530i
Engine: M54
Originally Posted by pipper' date='Jul 13 2005, 08:11 AM
no worries ICC, i will look up your post. many thanks.
[snapback]148649[/snapback]
I just did my 5k miles oil change. It took me about 45 minutes due to the first time to change oil in E60. Next oil change will be much less than 45 minutes.
I drove the car to rino ramp and unscrewed the cover (1 screw) to open the cover. The oil drain nut was facint the the passenger side wheel instead of the rear of the car. The drain nut was 17mm (same as my Volvo), and was amazingly "not" tight and "without" a copper washer ????
With the oil filler cap opened, I undid the drain nut and let the "dark" oil came out for about 10 minutes. Total oil that came out was about 6.5 quarts. Put back the drain nut with the copper washer and tightened the drain nut by hand first then wrench. I did not have the torque spec. for the drain nut so I just did it by feel.
Poured in 7 quarts of engine oil from the filler cap and put back the filler cap. I used a 36mm socket to unscrew the plastic oil filter cap. Once the filter cap was out, removed the oil filter element and installed the new filter element. Replaced the rubber o-rings on the filter cap and tightened the filter cap to 25 Nm as stated on the cap itself.
That was it.... Turned on the car and let it run for a couple minutes and checked for any oil leak from the drain nut and oil filter cap.
No oil service light came on and car ran great...... Next oil change will be at 10k miles.
Surely it does not make sense changing the oil without changing the oil filter at the same time? Why have new and expensive oil passing through an already contaminated oil filter?
Just my 2c worth!!
Streak
Just my 2c worth!!
Streak
many thanks
many thanks
Look up my name and I have a more in depth description of changing the oil and the filter. The next time it is due for my own oil change, I promised to take pictures and add my description. Should be ready in about a couple of months or so. Just had my "first" oil change at the dealer at 12K. Ridiculous, IMHO.
Regards,
Mike
My Ride: E60 530i
Engine: M54
Originally Posted by pipper' date='Jul 14 2005, 07:49 AM
did you guys find the oil or the oil filter contaminated when u did your first oil change?
[snapback]149027[/snapback]
Here is the link to the original thread. Look for my response.
http://forums.e60.net/index.php?showtopic=7947&st=15
Good Luck!
Regards,
Mike
OK maybe contaminated was a bad choice of words, dirty may have been better.
As Mike said, the oil filter does start to lose efficiency.
Once you are in DIY mode and doing an oil change, take the time to pop in a new filter your engine will love you for it!!
Streak
Streak
