Diversity Amplifier Replacement
Old 12-02-2016, 11:28 AM
  #61
Sergei.Klimov's Avatar
My Ride: 2008 M5
Default Still no sound in the car
Originally Posted by balbs
Did you try switching out the amplifier that has corrosion?
Yes I put the one from 2008 525 model, it didnt help
Old 12-02-2016, 11:33 AM
  #62
balbs's Avatar
My Ride: BMW
I think there is another component near the spare tire area that might have gotten wet that may cause this issue. However, I think BMW already fixed that on the 2008 models.
Old 12-02-2016, 11:59 AM
  #63
My Ride: 2008 M5
There is RDS module which I replaced and another small black box, which I do not know its purpose.
Do you think the amplifier has to be programmed, or just like diversity antenna need to work on the same frequency? Or they all have the same frequency to begin with? Thank you
Old 01-24-2017, 05:07 AM
  #64
okii's Avatar
Default What is white thing next to ground screw
Hi-
What is the white item in the first photo? This is an image behind the C-pillar covering, right? Is this an airbag? If so, is there a danger of activating this when removing the cover?
Thanks
Old 01-24-2017, 05:21 AM
  #65
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by okii
Hi-
Thanks
Yes, it is behind C-pillar. No sure what that white item was, it could be airbag. C-pillar cover does not touch that white item at all. There is ample of room/space between cover and this item. If you have concern, you can disconnect battery first and then proceed.
Old 02-17-2017, 09:25 AM
  #66
Brick Top's Avatar
My Ride: E60 530d M Sport
Brilliant write up thank you! Only took about 20 mins to replace my faulty amplifier today using this guide, first bit of diy on the new car done. Key fob works great now, I don't have to look like an idiot anymore getting it to lock and unlock
Old 07-23-2017, 12:48 AM
  #67
Bees42's Avatar
My Ride: 520d
I have a problem with my diversity aerial but cannot see your photos your help would be greatly appreciated
Old 07-23-2017, 01:16 PM
  #68
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Photobucket stopped free image hosting - not able to see photos anymore. I will try to upload them directly here.
Pictures upload is done.
Old 10-19-2017, 02:34 PM
  #69
Delboy999's Avatar
My Ride: E60 2005 530i
Model Year: E60
Engine: E60
Default BMW 530i 2005
My car has only done 2.000 miles and the keys don't work, I purchased a new one from BMW and that don't work either, now have to book car into workshops to try and find problem , hardly think it could be the diversity thing but it has got me thinking now
Old 04-14-2023, 09:23 AM
  #70
rickster1957's Avatar
My Ride: 2006 530i sport suspension, active roll control
Default E60 issues
Guys, thanks for the great info on this old thread. Got a related question; I recently bought my 530i very used.
a previous owner had driven some of the plastic fingers holding the diversity amp in. Is it possible to find a replacement bracket? With some missing fingers, I feel like the metal contacts may not be staying in touch with the metal pads.
Awest91
09-17-2022 11:05 PM
Eborlindum
03-23-2015 02:15 AM
fmusbmw
Bluetooth & Cell Phone Forum
05-14-2004 11:41 PM
fmusbmw
04-11-2004 04:13 PM
08-12-2003 11:41 AM
Quick Reply: Diversity Amplifier Replacement
