Debadging 530i trunk
7 Attachment(s)
Here's how I removed the trunk badges from my 530i. There's probably tons of other posts out there about how to do this, but this is my first post and I figured why not. This method worked well for me, but if there's better methods lemme know!
All I used for this was a heat gun, goo gone, plastic blade, and fishing line. -Started by making sure area around badges was clean. -Used heat gun to heat glue behind badges. I tried not to apply too much heat to the paint, just enough to get the glue soft. -Once glue is soft enough to wiggle the badges back and forth, use the fishing line to gently separate the badge from the trunk. -Used goo gone on a SOFT cloth and dabbed onto leftover glue. Make sure to keep glue generously saturated with goo gone. -Used a plastic blade to GENTLY scrape off last of the glue. -Used small amount of goo gone to remove the leftover glue. -In the end you can still see light silhouettes from where the badges were. -Used a polish compound to blend the paint together and tie it all together. Attachment 150145 Attachment 150146 Attachment 150147 Attachment 150148 Attachment 150149 Attachment 150150 Attachment 150151 |
nice, this is literally the first thing I do to any BMW I buy.
:thumbsup: i do this too all my cars. love the clean look
