Hello, when i start my car cooling fan turns on after about 4-7 seconds. Is it normal ? It seams to work at a high speed. It doesnt stop, always on! Any suggestions?Should i check my A/C preasure? Wires?
Hi ZBMW and welcome tp the forum.
Can you detail what engine and year your E60 is. |
Can you detail what engine and year your E60 is. Hello, the engine is N52 , BMW525i 2006 |
I don't think it should do that. Check coolant level. If it is HIGH, believe it or not, the fan tends to go on (at least in my car, though not so quickly).
| All times are GMT -8. The time now is 08:35 PM. |
