Changing from Pre Lci Lights to Lci Lights
Old Feb 24, 2013 | 06:32 AM
tom_il's Avatar
My Ride: BMW 525dA 2007 pre-LCI.
yeah I have also about it on bmwcoding but nobody actually has measured the voltage.
Fact is that for increasing the voltage you need a different technology then for lowering it. Its a big difference. BMW never intended to increase the voltage so why would it then be possible by coding ?
Old Feb 24, 2013 | 10:28 AM
BallyM5's Avatar
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic, Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release, Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi RoberMc i have fitted the lights and have wired only right light wire to lm module
i have also added the code to the VO and done fa write on cas and lm
i have coded it to the car by using expert profile by doing sg codin on lm module
when i turn on the lights the fog light comes on low power on its own
when i press the brake pedal the rods light up but not that bright and so does the inner bulb the outside bulb does light up
any idea whats wrong here i havnt changed any other wires around yet
the reverse light works
when i turn on the rear fog that goes brighter
but no rods lights up with lights on and brakes off
thaanks
Old Feb 24, 2013 | 03:37 PM
BallyM5's Avatar
i been studying the retro fit pdf and the wiring has changed in the 2007 and 2008 pdf file as there was errors in the 2007 bmw stopped selling this retrofit wiring kit
the wiring i brought was wired up exact how the 2007 pdf shows which was the one with the error
i changed the wires on both left and right wiring on pin 4 and pin 6 around. as this is how the retrofit wiring should have came as shown in the 2008 pdf and il test again tomorrow
Old Feb 24, 2013 | 04:08 PM
BallyM5's Avatar
Thanks for the reply I think it's caused by wiring as it seems its wired wrong
I did check the code was added into the vo and stayed there in cas didn't check it in lm il do that tomorrow
My expert profile is good as I have been doing quite abit coding and it does reset back to default without man file
Just to confirm when I do fa write to cas and then lm that copy's all the vo and vin to lm?
These were the functions that didn't work on front headlights inner ae rings , no main beam flasher
Old Feb 25, 2013 | 06:55 AM
BallyM5's Avatar
Default trace files
hi thanks for all your help so far RoberMc mate you been great
all the back lights are working i left the wires to the lm as they only turn on the inner brake bulbs
on the front the only problem i have is the inner rings are not working
i have after xenons fitted they work fine as before
just the inner rings not lighting up i did notice they light up when i brake for some reason my headlights are the standard halogen with after market xenon
heres trc files
Download multiple files from Sendspace.com - send big files the easy way
Old Feb 25, 2013 | 08:07 AM
BallyM5's Avatar
I forgot to mention the front flashers are not working too high beam
Old Feb 25, 2013 | 08:20 AM
BallyM5's Avatar
In that link there are two trace files please check again
Old Feb 25, 2013 | 08:44 AM
BallyM5's Avatar
just to confirm onr trace is the lm1 with every thing original connected from car
second one of the lm2 coded to car with +mueb added to fa and all back lights working
but faults on front ones the inner angel eye rings dont light up when turned on
the light up when i press the brake pedal?
and the main beam flasher doesnt work
do you want me to remove +mueb off from the vo and reset cas and lm and then send trc?
thanks for your help buddy
Old Feb 25, 2013 | 08:50 AM
BallyM5's Avatar
must of copied a wrong one by mistake il do it again sorry for the confusion
how shall i get you the lm2 trace with working pre lci lights would that we done by removing the code from VO and resetting lm2 with expert profile?
LM2 trace do you want the one with the FA code added to Vo too thanks
Old Feb 25, 2013 | 09:10 AM
BallyM5's Avatar
lm2 with working front lights +MUEB REMOVED.TRC - Speedy Share - upload your files here
lm2 WITH +MUEB ADDED NON WORKING FRONT LIGHTS.TRC - Speedy Share - upload your files here
