Changing the orange LED to white LED on the cluster to look like M5 or
Old 11-08-2009, 09:45 AM
  #151
Alfonze's Avatar
My Ride: 2005 545iA
Correct me if im wrong. If i only want to change the LED-s, i dont need to get the dials off? I just replae the LED-s and paint the dials on top, and that's it? If so, it seems like doable, and i think im going for it:-)
Old 11-08-2009, 04:52 PM
  #152
pinguhk's Avatar
My Ride: Mini Cooper
you will need to take the dials off or you can not get to the led lights
Old 11-08-2009, 11:41 PM
  #153
Alfonze's Avatar
My Ride: 2005 545iA
OK, i'll try to get them off then:-P They come off easy?
Old 11-09-2009, 12:12 AM
  #154
pinguhk's Avatar
yes they are not stick on so it should come come.
I used a card to rest the tweezers on to push it up so it dose not scratch the black dial.
Old 11-09-2009, 02:07 AM
  #155
Alfonze's Avatar
My Ride: 2005 545iA
One more question, how do i know, how to put the dial on, so it will be exactly on zero position? Same thing on the bottom plates (the ones for cruise and engine temp indicator).
Are these LED-s ok? : LED-s
Sorry about the language on the website, but the spec-s are understandable.
Old 11-09-2009, 05:11 AM
  #156
pinguhk's Avatar
for the main plate just plug in the power back on but dont install the cluster just yet.
and the dial will go to 0 and then turn it off again and put the 2 main needles back on.
you will have to put back the needle by eye.
it same for the for the small 1s
Old 11-09-2009, 05:12 AM
  #157
pinguhk's Avatar
for the size ricky will have to tell you if they are right or not
Old 11-09-2009, 05:27 AM
  #158
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Correct and should work fine if in white color.
Old 11-09-2009, 05:37 AM
  #159
ricky1329's Avatar
connect the cluster without needle; without cover, turn your key to position 2 and then turn off. All dial in zero position, Now put your needle back.
Old 11-09-2009, 07:39 AM
  #160
Alfonze's Avatar
My Ride: 2005 545iA
I have brought the LED-s (the price was around 5-6 USD for 10pcs. :-)).
About the needle, does it have a separate LED, if so, why not change it too to red and no painting needed?
If these can not be changed, what is the best way to colour the needles:
1. on the current white paint with marker
2. scrape off the white and then marker
3. use a red tape instead of marker
Quick Reply: Changing the orange LED to white LED on the cluster to look like M5 or
