Changing the orange LED to white LED on the cluster to look like M5 or
Old 02-26-2009, 03:11 AM
pinguhk's Avatar
My Ride: Mini Cooper
1st thing to do is unplug the battery.
01. Before the change.
Changing the orange LED to white LED on the cluster to look like M5 or-001_changing_white_led_on_cluster.jpg
02. There are 2 screws at the top which need to be undone to take out the cluster.
Changing the orange LED to white LED on the cluster to look like M5 or-002_changing_white_led_on_cluster.jpg
03. At the back there is a plug which need to take off.
Changing the orange LED to white LED on the cluster to look like M5 or-003_changing_white_led_on_cluster.jpg
04. Undo these 4 screws with a T10 screw driver
Changing the orange LED to white LED on the cluster to look like M5 or-004_changing_white_led_on_cluster.jpg
05. Undo the 4 clips by pushing it down and out.
Changing the orange LED to white LED on the cluster to look like M5 or-005_changing_white_led_on_cluster.jpg
06. Undo the 2 clips, then take off the casing.
Changing the orange LED to white LED on the cluster to look like M5 or-006_changing_white_led_on_cluster.jpg
07. Use a card and a fork to take off the needles, don't use too much force cos they will brake very easy.
Changing the orange LED to white LED on the cluster to look like M5 or-007_changing_white_led_on_cluster.jpg
Changing the orange LED to white LED on the cluster to look like M5 or-008_changing_white_led_on_cluster.jpg
08. At the back turn the plastic ring in the center clockwise to undo the ring and panel.
Changing the orange LED to white LED on the cluster to look like M5 or-009_changing_white_led_on_cluster.jpg
Changing the orange LED to white LED on the cluster to look like M5 or-010_changing_white_led_on_cluster.jpg
09. Undo the 2 screws with a T9 screw driver.
Changing the orange LED to white LED on the cluster to look like M5 or-011_changing_white_led_on_cluster.jpg
10. Take off the gear for the Cruise Control ring and rev ring.
Changing the orange LED to white LED on the cluster to look like M5 or-012_changing_white_led_on_cluster.jpg
11. You will see the 4 LEDs in each of the ring.
Changing the orange LED to white LED on the cluster to look like M5 or-013_changing_white_led_on_cluster.jpg
12. At the back. The board is fixed to a socket so just undo the board by pulling it up slowly.
Changing the orange LED to white LED on the cluster to look like M5 or-014_changing_white_led_on_cluster.jpg
13. Take out the LED board.
Changing the orange LED to white LED on the cluster to look like M5 or-015_changing_white_led_on_cluster.jpg
Changing the orange LED to white LED on the cluster to look like M5 or-016_changing_white_led_on_cluster.jpg
14. You will see 4 LEDs on each ring.
Changing the orange LED to white LED on the cluster to look like M5 or-017_changing_white_led_on_cluster.jpg
15. Use a solder iron to take off the old LEDs .
Changing the orange LED to white LED on the cluster to look like M5 or-018_changing_white_led_on_cluster.jpg
Changing the orange LED to white LED on the cluster to look like M5 or-019_changing_white_led_on_cluster.jpg
16. For the new 1s you will need 8 white LEDs. Solder the new white LEDs back on. Each ring will need 4 LEDs. On each led legs there will be a + and - for the power so get a multi meter to test which is which. If solder wrongly it will not light up.
Changing the orange LED to white LED on the cluster to look like M5 or-020_changing_white_led_on_cluster.jpg
17. On the white case use some double sided tape to sick down the board coz if not the board will not stay in place.
Changing the orange LED to white LED on the cluster to look like M5 or-021_changing_white_led_on_cluster.jpg
18. Spray the ring which ever colour you like.
Changing the orange LED to white LED on the cluster to look like M5 or-022_changing_white_led_on_cluster.jpg
Changing the orange LED to white LED on the cluster to look like M5 or-023_changing_white_led_on_cluster.jpg
19. For the needle paint them red.
Changing the orange LED to white LED on the cluster to look like M5 or-024_changing_white_led_on_cluster.jpg
Changing the orange LED to white LED on the cluster to look like M5 or-025_changing_white_led_on_cluster.jpg
Changing the orange LED to white LED on the cluster to look like M5 or-026_changing_white_led_on_cluster.jpg
Changing the orange LED to white LED on the cluster to look like M5 or-027_changing_white_led_on_cluster.jpg
20. There you go finished here is the end product.
Changing the orange LED to white LED on the cluster to look like M5 or-028_changing_white_led_on_cluster.jpg
Changing the orange LED to white LED on the cluster to look like M5 or-029_changing_white_led_on_cluster.jpg
I would like to say many thanks to ricky1329 helping to make this dream come true.
If it was not for him this mod would never have happened and I would not have done a DIY.
If you what any more info on any thing about this mod, please ask us in the Topic and we would be happy to post it up for every 1 to read.
If you would like to buy a set of white LEDs please pm me for a price.
Old 02-26-2009, 03:26 AM
MarcsOnFire's Avatar
My Ride: 535d M-Sport '06 Plate - Carbon Black - Black Leather - Pro Sat Nav - Logic 7 - HUD - Bluetooth - Privacy Glass - 172M 19" Alloys - Heated Seats - PDC - Adaptive Headlights - Extended Voice Control - Paintshield Extended - M5 Boot Finisher - Bright White LED Internal Lighting - Dension Gateway 500 Ipod/USB/Aux Integration
Awesome mate! Very scary for someone like me, but very, very cool. I might build up the courage at some point to do it.
Cheers
Marc
Old 02-26-2009, 03:45 AM
nigxdoof's Avatar
Looks great man!! it is a little risky / scary too.
I think about doing that.. i'm just scared to mess up the gauges / needles.
Old 02-26-2009, 03:53 AM
bimmerspeed's Avatar
My Ride: /// 2006 | 530I | Silver Gray Metallic | Sport / Prem / Navi / IPod | LCI EURO SPEC Tail's | LED Licence plate bulbs | LED side turn indicators | Roof Spoiler MORE TO COME!!!!
Im up for the challenge, WHO'S IN????
Now i just need some time, looks pretty time consuming...
As far as the white paint goes, you used glossy white, or a color of your preference with GLOSS??
Old 02-26-2009, 04:00 AM
pinguhk's Avatar
it you know what you are doing it only takes about 1 hour.
but if you guessing then I would say 3 to 4 hours
Old 02-26-2009, 04:39 AM
Patrick E61's Avatar
My Ride: 2005 BMW 530d M-Sport TouringExterior: Titansilber Metallic, M5 mirrors, ACS rear roof spoiler, BMW Carbon Fiber rear diffuser, Adaptive Xenon headlights, AngeliBright v.3 Angel Eyes, F1 Autohaus Euphoria 6000K LED license plate lightsInterior: Black
+1
Although the end result is excellent!
I have a different instrument cluster plan in mind.
Old 02-26-2009, 04:45 AM
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Pingu, the procedure little bit mix up . Should done point 12 and point 13 top first before point 7.
After waited the paint fully dry, reverse the procedure but please not put the needle first.
1. Connect the cluster without glass cover and need.
2. Connect back the battery
3. Turn key on to position 2
4. Back to position 1, then all needle should on zero level
5. Pull back the needle and turn key to position 2 then position 1 to verify the needle on correct postion or not
6. If needle postion correct then turn off key
7. un-plug battery
8. un-plug cluster back side connect
9. cover back the cluster cover.
10. plug back battery and become finish.
I am so lazy which just use the red color permenant marker repaint the needle back, if not the needle still orange incolor while light on.
I haven't paint the back ring which keep on black in color, but when light on become a white ring. if not the needle still orange incolor while turn on.
Good luck for every buddies
Old 02-26-2009, 05:07 AM
Dr Dave's Avatar
well done your a brave man.
Old 02-26-2009, 05:30 AM
bimmer530iguy's Avatar
My Ride: 5series
Nice DIY pingy, just one question is it possible to try a different color besides white maybe blue? white is nice too, but if I commit to doing this I would like to try something different. What type #'s are the led?
Old 02-26-2009, 05:39 AM
ricky1329's Avatar
Yes, change from amber to blue also ok. Type side 3528. Any color should also ok and up to your good choice.
Quick Reply: Changing the orange LED to white LED on the cluster to look like M5 or
