changing a headlight bulb
My Ride: 06' 530 Alpine/Auburn/Dark walnut, Sport, Premium, Sirius, 35% Tint
Upcomming mods: M166's/Exclaim UHP's, Mtech
Can anybody give me the proceedure for replacing a burned out zenon bulb on an 06' 530. Did a search, but got no useable results.
I don't know about the 5-Series but on the 6 there are 2 screws in the wheel well torwards the front. undo those and a flap comes down which gives you access to headlight bulb
My Ride: AW E46 M3 Vert
there are 2 big torx screws on top of each headlight, one on the outside corner of the headlight and the other almost in the middle...unscrew those. then get a flash light and you will see there are 2 smaller screws behind the headlight at the bottom holding it as well, get an extension and a socket and carefully unscrew those 2 as well (torx screw as well i think). at this point you should be ready to pull on the headlight and feel it moving around.
heres the hard part.... try to maneuver that thing out without scratching the fender or bumper. eventually you'll figure out the best way to get it out and should be able to leave everything plugged in while getting to the back of the headlight with plenty of room to work.
btw: i found it easier to pull the headlight out and put back in if you remove the back cover where the drl's are (where the inner bulbs sit) you'll see it, its like a circular cover that just twists off.
good luck
Originally Posted by e60_fanatic' post='781601' date='Jan 31 2009, 01:13 AM
unfortunately you have to pull the whole headlight out...
good luck
good luck
I'm not sure what type of bulb I should bye and where from.
I've been looking online ant it looks like there are two different types of bulbs, D1S and D2S. there's also different brightness (4300k, 5000k, 6000k etc...), and they also talk about a low beam bulb and a high beam bulb which is confusing to me because I thought that the same bulb had both low and high beam.
I'm interested in getting the same kind that I had before, does anyone know exactly what type of bulb I should use?
Any help would be greatly appreciated. I need to get this taken care of right away before I get pulled over.
Banned
My Ride: A Car
Originally Posted by ziad' post='913165' date='Jun 16 2009, 10:20 AM
Ok, so my left headlight went out a couple days ago. I have a 2004 525i, xenon.
D1S bulb.
D2S bulb.
Those r not my pictures. Take out the headlight and the bulb should also read which type of bulb. If u need to purchase any lighting equipment, feel free to contact me.
My Ride: None
good luck
good luck
My Ride: None
Yeah i'm sure it's the same. You'll need an extended tool to reach the lower back 2 screws... but it's easy to do and thank god we don't have to take off the bumper lol.
The OP should search for AE installation DIYs as they also have good pics showing headlight removal.
socale39
09-05-2023 08:30 AM
Tsoup
15
12-20-2021 11:14 AM
