CCC Nav / MASK Business Upgrade Coding with NCS
My Ride: 2006 M5
![Red face](https://5series.net/forums/images/icons/icon11.gif)
Hopefully we can create a step by step procedure with this topic for other members...
First off, is it possible to completely re-code our systems with NCSExpert when we do an upgrade to a CCC - NAV Pro from MASK - Business? Perhaps some experienced members can chime in please.
If so, what needs to happen here?
From what I've read, I need to re-code/FLASH my FA with '$609' which activates CAPPL (CCC) Modules. I've done this with some success... I was able to read/write to the module but when I disconnect and read my FA again, $609 is no longer part of the list and I can not see the CAPPL module. How do I make it permanent? Am I missing other codes & what are they?
Like I said, I've already made some changes with NCSExpert to the CAPPL module but I'm still missing my audio output which should be set to 'top_hifi' like my old MASK unit. Right now all audio/volume settings are set to 'standard' on the CAPPL and I haven't been able to change them. Note: If another member has a Logic 7 audio system and could share their CAPPL txt file I would appreciate it.
I've also read I need to re-code the AMP but that doesn't make sense since the AMP is still waiting for the audio via fiber optic output from CAPPL module to the system.
Did you use FA_write to write $609 to the LMA and CAS?, then do a complete vehicle re-code with the standard expert profile. When doing retrofits it`s allays best to use the standard expert profile as it uses the VO to set the module parameters.
My Ride: 2006 M5
Thnanks for the feedback Blood. I was able to FA_Write the $609 permanently without any problem.
I have changed a few of the Volume paremeters to e60_top_hifi with no success. Every time I try to change the Audio parameter from e60_hifi to e60_top_hifi, NCSExpert goes thru the coding process but when i go back and read it, it doesn't change... Any other parameter I change from nicht_activ to activ, changes without any problem.
If anyone can post their e60 Logic 7 CAPPL file I'd appreciate it.
My Ride: 2012 535i M-Sport
K931D_ZV_ALLE_TUEREN
par_frei
K931D_ZV_SELEKTIV
par_frei
K930E_ZV_VER_N_XMIN_FB
fkt_frei
K9901_WARNBLINKEN
par_gesperrt
K9323_ZV_VER_AB_X_KM/H
fkt_frei
K8129_ZWAKO_AC_EIN_AUTO
fkt_gesperrt
K7504_HEIMLEUCHTEN_AUS
par_frei
K7504_HEIMLEUCHTEN_40S
par_frei
K7504_HEIMLEUCHTEN_90S
par_frei
K7504_HEIMLEUCHTEN_150S
par_frei
K7504_HEIMLEUCHTEN_240S
par_frei
K4328_BLINKEN_TIPPBET
fkt_frei
K5303_GAL_SEHR_STARK
par_frei
K8116_KLAPPENAUTOMATIK
fkt_gesperrt
K5303_GAL_STARK
par_frei
K5303_GAL_MITTEL
par_frei
K5303_GAL_GERING
par_frei
K5303_GAL_SEHR_GERING
par_frei
K5303_GAL_KEINE_ANHEB
par_frei
K5305_KLANG_BASS
par_frei
K5305_KLANG_TREBLE
par_frei
K5305_KLANG_BALANCE
par_frei
K5305_KLANG_FADER
par_frei
K5305_KLANG_REVERB
par_frei
K5305_KLANG_EQULIZER
par_frei
K531A_LAUTST_NAV
par_frei
K531A_LAUTST_VERKEHR
par_frei
K531A_LAUTST_TELEFON
par_frei
K531A_LAUTST_SVS
par_frei
K531A_LAUTST_PDC
par_frei
K4310_ANZ_SPRACHE_1
par_frei
K4310_ANZ_SPRACHE_2
par_frei
K4310_ANZ_SPRACHE_3
par_frei
K4110_VERBR_L/100KM
par_frei
K4110_VERBR_MPG_US
par_frei
K4110_VERBR_MPG_UK
par_frei
K4110_VERBR_KM/L
par_frei
K410D_EINHEITEN_WEG
fkt_frei
K4113_ZEIT_STD_DARST
fkt_frei
K4116_EINH_TEMPERATUR
fkt_frei
K9901_UMLUFT_EIN
par_frei
K9901_NAV_LETZER_HINWEIS
par_frei
K9901_KOMFORT_PARKBREMSE
par_frei
K9901_MUTE_EIN
par_frei
K9901_MONITOR_EIN
par_frei
K9901_LENKRADHEIZUNG
par_frei
K9901_RADIO/TELEFON
par_frei
K9901_SWR
par_gesperrt
K430C_DATUM_FORMAT
fkt_frei
C750A_SCHWELLWERT_EMPFIN
par_gesperrt
C750A_SCHWELLWERT_NORMAL
par_gesperrt
C750A_SCHWELLWERT_SEHR_E
par_gesperrt
DRUCK_EINHEIT
psi
K8601_SOLLWERT_M3
par_gesperrt
K8601_SOLLWERT_M2
par_gesperrt
K8601_SOLLWERT_M1
par_gesperrt
K8601_SOLLWERT_0
par_gesperrt
K8601_SOLLWERT_P1
par_gesperrt
K8601_SOLLWERT_P2
par_gesperrt
K8601_SOLLWERT_P3
par_gesperrt
K4D01_OFF_CID_DISPL_HELL
fkt_frei
K4119_DRUCK_BAR
par_frei
K4119_DRUCK_PSI
par_frei
K4119_DRUCK_KPA
par_frei
K8313_GEBLAESE_M10
par_gesperrt
K8313_GEBLAESE_0
par_gesperrt
K8313_GEBLAESE_P10
par_gesperrt
K9901_HUPE
par_gesperrt
C940C_QUITT_OPT_ENTSCH
fkt_gesperrt
C940D_QUITT_OPT_SCHAERF
fkt_gesperrt
C940A_QUITT_OPT_ENTSCH
fkt_frei
C9419_QUITT_OPT_KLAPPE
fkt_frei
C9410_QUITT_OPT_SCHAERF
fkt_frei
C941C_QUITT_AKUST_KLAPPE
fkt_frei
K9416_QUITT_AKUST_ENTSCH
fkt_frei
C9413_QUITT_AKUST_SCHAERF
fkt_frei
K8119_PRG_AUTOMATIK
par_gesperrt
K8119_PRG_LUFTVERTEILUNG
par_gesperrt
K8127_KLAPPENPROGRAMM_BO
fkt_frei
K8119_PRG_GEBL_AKTUELL
par_gesperrt
K8119_PRG_SCHICHTUNG
par_gesperrt
K8119_PRG_AC
par_gesperrt
K8125_KLAPPENPROGRAMM_BO
fkt_frei
K532F_SENDERLISTE_AUDIO
fkt_gesperrt
K4D01_OFF_HUD_DISPL_HELL
fkt_gesperrt
K4D03_ANZEIGE_GESCHWNDGKT
par_gesperrt
K4D03_ANZEIGE_CHECKCONTRL
par_gesperrt
K4D03_ANZEIGE_ACC
par_gesperrt
K4D03_ANZEIGE_TEMPOMAT
par_gesperrt
K4D03_ANZEIGE_NAVIGATION
par_gesperrt
K2407_PDC_MONITORBILD
fkt_frei
CA107_AUT_VERST_DEAKT
par_frei
CA107_AUT_VERST_ENTR
par_frei
CA107_AUT_VERST_ENT_T
par_frei
C9C03_KLAPPENWINKEL
fkt_gesperrt
C9C01_HKL_TASTE
fkt_gesperrt
K931D_SCHEIBENABSENKUNG
par_gesperrt
NIVI
nicht_aktiv
CDC
aktiv
MMC
nicht_aktiv
AUDIO_SYSTEM
e60_top_hifi
pl2_top_hifi
e70_top_hifi
SVS
nicht_aktiv
NOTEPAD
nicht_aktiv
SDARS
nicht_aktiv
BMW_ASSIST
aktiv
HELPNET
nicht_aktiv
PDC
aktiv
HUD
nicht_aktiv
ELDRVSEAT
aktiv
MFL_HORN
nicht_aktiv
MFL_HAZARD
nicht_aktiv
MFL_CLEAN
nicht_aktiv
FOND_HIGH
nicht_aktiv
FOND_LOW
nicht_aktiv
LAENDERVARIANTE_TUNER
us
TP_FUNKTION
nicht_aktiv
TP
nicht_aktiv
TMC
nicht_aktiv
AMBANDS
nicht_aktiv
BAUREIHE
e60
e63
e64
e61
BAUART
limousine
CODIERUNG_ERFOLGT
codierung_erfolgt
TWO_MICROPHONES
wert_01
TYP_LENKUNG
linkslenker
ACC
nicht_aktiv
WAEHLBARE_SPRACHE_1
us
WAEHLBARE_SPRACHE_2
franzoesisch
WAEHLBARE_SPRACHE_3
spanisch
ADRBOOK
aktiv
WEG_EINHEIT
mls
AEREA_CODE_DVD
wert_01
DWS
aktiv
BMW_N_DEALER
nicht_aktiv
TRF
nicht_aktiv
KANA_WRITER
nicht_aktiv
SMS
nicht_aktiv
WEATHERBAND
aktiv
LEGAL_DISCL
nicht_aktiv
REV_INPUT
aktiv
UNIT_FEET
aktiv
ACOUSTIC
aktiv
TEMPERATUR_EINHEIT
grad_f
ZEIT_EINHEIT
12_stunden
DATUM_EINHEIT
mm_tt_jj
NAVIGATION
aktiv
BACKDOOR
nicht_aktiv
STANDHEIZUNG
nicht_aktiv
DIGITAL_AUDIO_SOURCE
cd-player
PHONE_VERSION
most-phone1-1mic
BA_LAENDER_VARIANTE
usa
DEF_DATUM_EINHEIT
mm_tt_jj
DEF_DRUCK_EINHEIT
psi
DEF_TEMPERATUR_EINHEIT
grad_f
DEF_WEG_EINHEIT
mls
DEF_ZEIT_EINHEIT
12_stunden
JAPAN
nicht_aktiv
MULTIPARTY
nicht_aktiv
NAVIGATION_TYPE
navi_sv
ONLINE
nicht_aktiv
ONLINE_DISABLE_CONTENT
content_enable
ONLINE_DISABLE_VMAX
standard
REVERSE_GONG
nicht_aktiv
SIM
nicht_aktiv
SPRECHER_AKTIVE_SPRACHE
sprecher_weiblich
SPRECHER_ALTERNATIVE_2
sprecher_weiblich
SPRECHER_ALTERNATIVE_3
sprecher_weiblich
DEF_BALANCE_VOLUME
standard
DEF_BASS_VOLUME
standard
DEF_ENTERTAIN_VOL
standard
DEF_EQUALIZER_VALUE
standard
DEF_FADER_VOLUME
standard
DEF_GAL_VALUE
keine_anhebung
DEF_GONG_VOLUME
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
DEF_JPGONG_VOL
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
DEF_LAST_SPEECH
us
DEF_NAVI_VOLUME
standard
DEF_PDC_VOLUME
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
DEF_REVERB_VALUE
standard
DEF_SEC_VOLUME
standard
DEF_SPEECH_VOLUME
standard
DEF_TEL_VOLUME
standard
DEF_TM_VOLUME
standard
DEF_TREMBLE_VOLUME
standard
GAL_VALUE
keine_anhebung
LAST_BALANCE_VOLUME
standard
LAST_BASS_VOLUME
standard
LAST_ENTERTAIN_VOL
standard
LAST_EQUALIZER_VALUE
standard
LAST_FADER_VOLUME
standard
LAST_GONG_VOLUME
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
LAST_JPGONG_VOL
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
LAST_PDC_VOLUME
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
LAST_REVERB_VALUE
standard
LAST_SEC_VOLUME
standard
LAST_SPEECH
us
LAST_SPEECH_VOLUME
standard
LAST_TM_VOLUME
standard
LAST_TREMBLE_VOLUME
standard
EINH_MASTER_KOMBI
nicht_aktiv
ONLINE_CALLSTRATEGY
use_csd_paketdata
CRUISE_CTRL_CCC
nicht_aktiv
OIL_LEVEL
aktiv
CBS
cbs_3
CID_CCC
cid_high
CID_COLOUR
table_1
CID_TYPE
static
KLIMA_SG_ART_CCC
high
PDC_SIGNAL
pdc_no
PDC_TYPE
full
PIA
ckm
VA_FLAP_CC
nicht_aktiv
VA_FLAP_DISPLAY_CONFIG
nicht_aktiv
VA_FLAP_HMISTART
nicht_aktiv
VA_FLAP_NAVI
nicht_aktiv
VA_FLAP_PHONE
nicht_aktiv
VA_FLAP_SVS
nicht_aktiv
RDC_CCC
aktiv
AUTO_DRV_LIGHT
nicht_aktiv
C7501_TAGFAHRLICHT
fkt_gesperrt
HDC
nicht_aktiv
RAIN_LIGHT_SENSOR
nicht_aktiv
STANDLUEFTUNG_CCC
aktiv
MDRIVE
nicht_aktiv
MDRIVE_ALBV
nicht_aktiv
MDRIVE_SMG
aktiv
BLUETOOTH_NODES_CCC
profil_2
HUD_M
nicht_aktiv
MAX_PHONE_VOL
standard
e60_stereo
e60_hifi
e60_top_hifi
e61_stereo
e61_hifi
e61_top_hifi
e63_stereo
e63_hifi
e63_top_hifi
e64_stereo
e64_hifi
e64_top_hifi
e87_stereo
e87_hifi
e87_top_hifi
r56_stereo
r56_hifi
e90_stereo
e90_hifi
e90_top_hifi
e91_stereo
e91_hifi
e91_top_hifi
e92_stereo
e92_hifi
e92_top_hifi
MFL_MENU
nicht_aktiv
AUX_CONFIG
mounted
VA_BPI
aktiv
HIP
aktiv
RDS_AF_FUNKTION_CCC
rds_ein_af_aus
MP3_CCC
full
IBOC_CCC
nicht_aktiv
NIVI_DISPLAY_OPTIONS
main_or_fullscreen
RVC
nicht_aktiv
RVC_CONNECTED_TO_VM
nicht_aktiv
RVC_DISPLAY_OPTIONS
main_or_fullscreen
TOWBAR
nicht_aktiv
SVS_MICROPHONE_PATH
most
ALLOW_GPS
aktiv
BMW_DEALER_CCC
aktiv
BMW_HOTLINE_CCC
nicht_aktiv
BMW_MOBILE_CCC
aktiv
DAY_RUN_LIGHT_CCC
aktiv
DSC
nicht_aktiv
ROLLER_COVER
nicht_aktiv
ZBE
high
DAB
nicht_aktiv
DAB_BAND_SETTINGS
nicht_aktiv
DAB_FM_SWITCH
nicht_aktiv
REAR_HEAD_UNIT
nicht_aktiv
VA_MP3_DISCLAIMER
nicht_aktiv
FOND_MID
nicht_aktiv
CA_TMC
nicht_aktiv
JAP_SIDEVIEW_CAM
nicht_aktiv
LEGAL_DISCL_TIMOUT
standard
TOP_AMPL_TYPE
logic_7
VA_ADAPTIVEHEADLIGHT
aktiv
VA_CORNERINGLIGHT
aktiv
VA_FB
nicht_aktiv
VA_FB_COMMUNICATION
nicht_aktiv
VA_FB_ENTERTAINMENT
nicht_aktiv
VA_FB_NAVIGATION
nicht_aktiv
VA_FM_AM_TOGGLE
nicht_aktiv
VA_FOND_CLIMATE
nicht_aktiv
VA_LONGDISTANCELIGHT
nicht_aktiv
VA_MANUAL_SHIFT
nicht_aktiv
VA_MODE_TOGGLE
nicht_aktiv
VA_NOAIRVENT_FINETUNING
nicht_aktiv
VA_SEATVENTILATION
nicht_aktiv
VA_WELCOMELIGHT
aktiv
CAR_COLOR_CHAMP
nicht_aktiv
TELEFON_TYPE_C08
prof_phone
VA_AIRVENT_SHORTCUT
nicht_aktiv
VA_AUTOMATIC_SHORTCUT
nicht_aktiv
VA_PDC_LOW
nicht_aktiv
VA_SEATCLIMA_SHORTCUT
aktiv
VA_SEATHEAT_SLIDER
aktiv
DVD_EJECT_LOCKED
free
AUDIO_VOLUME_STEPS
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
e87_top_hifi
e90_top_hifi
e91_top_hifi
e92_hifi
e92_top_hifi
e70_top_hifi
e71_hifi
e71_top_hifi
e93_top_hifi
e81_top_hifi
e82_hifi
e82_top_hifi
e88_top_hifi
FULLWORD_RECOG
aktiv
CC_LIST
aktiv
DKG
nicht_aktiv
EDC
nicht_aktiv
CBS_STATUS
aktiv
CLIMATE_WO_PREVIEW
nicht_aktiv
NO_DETOUR
nicht_aktiv
ALBV_TOGGLE_APP
nicht_aktiv
BGSCREEN_JUMP
aktiv
DAB_FROM_FM
wert_01
DAB_TO_FM
wert_01
MEDIA_CHAR_ENCODING
iso
MM_DEVICE
nicht_aktiv
MM_DEVICE2
nicht_aktiv
NEXT_SOURCE
nicht_aktiv
OLD_TELEMAT_STRUCT
aktiv
TLC
nicht_aktiv
VA_HANGUL_TYPEWRITER
nicht_aktiv
VA_KANJI_TYPEWRITER
nicht_aktiv
TDA_ASC_STATUS
nicht_aktiv
TDA_BDA_STATUS
nicht_aktiv
TDA_CFG_AUTO_TRIG
nicht_aktiv
TDA_CFG_CUST_MOBILE_USE
aktiv
TDA_CFG_HLC_DATA
nicht_aktiv
TDA_CFG_IND_PDM_GR_NBR
file0
TDA_CFG_SER_ERR_SINK
aktiv
TDA_CFG_VEHICLE_SER
nicht_aktiv
TDA_DEACTIVATE_STATUS
aktiv
TDA_HLC_STATUS
nicht_aktiv
TDA_MSC_STATUS
nicht_aktiv
TDA_SERVICE_STATUS
nicht_aktiv
TDA_TDC_STATUS
nicht_aktiv
MDRIVE_LOW_CCC
nicht_aktiv
SITZHEIZUNG_APP_9
aktiv
CCC_E71
nicht_aktiv
NAVI_PFEIL
aktiv
TELESERVICE
nicht_aktiv
MDRIVE_MENU
nicht_aktiv
RSEMIDPLUS_AVAILABLE
nicht_aktiv
SVR
nicht_aktiv
TV_FRONT_ENABLED
nicht_aktiv
VEHICLE_FINDER
nicht_aktiv
VIDEO_DENY_C0B
deny_slow_key
ONLINE_DAR_TYPE_B
dar_us
VIDEOMODUL_CCC_B
nicht_aktiv
DEF_VERBRAUCH_CCC
mpg
TMC_REGIONAL_C
nicht_aktiv
VERBRAUCH_CCC
mpg
par_frei
K931D_ZV_SELEKTIV
par_frei
fkt_frei
K9901_WARNBLINKEN
par_gesperrt
fkt_frei
fkt_gesperrt
par_frei
par_frei
par_frei
par_frei
par_frei
fkt_frei
par_frei
fkt_gesperrt
K5303_GAL_STARK
par_frei
K5303_GAL_MITTEL
par_frei
K5303_GAL_GERING
par_frei
par_frei
par_frei
K5305_KLANG_BASS
par_frei
K5305_KLANG_TREBLE
par_frei
K5305_KLANG_BALANCE
par_frei
K5305_KLANG_FADER
par_frei
K5305_KLANG_REVERB
par_frei
par_frei
K531A_LAUTST_NAV
par_frei
par_frei
par_frei
K531A_LAUTST_SVS
par_frei
K531A_LAUTST_PDC
par_frei
K4310_ANZ_SPRACHE_1
par_frei
K4310_ANZ_SPRACHE_2
par_frei
K4310_ANZ_SPRACHE_3
par_frei
K4110_VERBR_L/100KM
par_frei
K4110_VERBR_MPG_US
par_frei
K4110_VERBR_MPG_UK
par_frei
K4110_VERBR_KM/L
par_frei
K410D_EINHEITEN_WEG
fkt_frei
fkt_frei
fkt_frei
K9901_UMLUFT_EIN
par_frei
par_frei
par_frei
K9901_MUTE_EIN
par_frei
K9901_MONITOR_EIN
par_frei
par_frei
K9901_RADIO/TELEFON
par_frei
K9901_SWR
par_gesperrt
K430C_DATUM_FORMAT
fkt_frei
par_gesperrt
par_gesperrt
par_gesperrt
DRUCK_EINHEIT
psi
K8601_SOLLWERT_M3
par_gesperrt
K8601_SOLLWERT_M2
par_gesperrt
K8601_SOLLWERT_M1
par_gesperrt
K8601_SOLLWERT_0
par_gesperrt
K8601_SOLLWERT_P1
par_gesperrt
K8601_SOLLWERT_P2
par_gesperrt
K8601_SOLLWERT_P3
par_gesperrt
fkt_frei
K4119_DRUCK_BAR
par_frei
K4119_DRUCK_PSI
par_frei
K4119_DRUCK_KPA
par_frei
K8313_GEBLAESE_M10
par_gesperrt
K8313_GEBLAESE_0
par_gesperrt
K8313_GEBLAESE_P10
par_gesperrt
K9901_HUPE
par_gesperrt
fkt_gesperrt
fkt_gesperrt
fkt_frei
fkt_frei
fkt_frei
fkt_frei
fkt_frei
fkt_frei
K8119_PRG_AUTOMATIK
par_gesperrt
par_gesperrt
fkt_frei
par_gesperrt
par_gesperrt
K8119_PRG_AC
par_gesperrt
fkt_frei
fkt_gesperrt
fkt_gesperrt
par_gesperrt
par_gesperrt
K4D03_ANZEIGE_ACC
par_gesperrt
par_gesperrt
par_gesperrt
fkt_frei
par_frei
par_frei
par_frei
C9C03_KLAPPENWINKEL
fkt_gesperrt
C9C01_HKL_TASTE
fkt_gesperrt
par_gesperrt
NIVI
nicht_aktiv
CDC
aktiv
MMC
nicht_aktiv
AUDIO_SYSTEM
e60_top_hifi
pl2_top_hifi
e70_top_hifi
SVS
nicht_aktiv
NOTEPAD
nicht_aktiv
SDARS
nicht_aktiv
BMW_ASSIST
aktiv
HELPNET
nicht_aktiv
PDC
aktiv
HUD
nicht_aktiv
ELDRVSEAT
aktiv
MFL_HORN
nicht_aktiv
MFL_HAZARD
nicht_aktiv
MFL_CLEAN
nicht_aktiv
FOND_HIGH
nicht_aktiv
FOND_LOW
nicht_aktiv
us
TP_FUNKTION
nicht_aktiv
TP
nicht_aktiv
TMC
nicht_aktiv
AMBANDS
nicht_aktiv
BAUREIHE
e60
e63
e64
e61
BAUART
limousine
CODIERUNG_ERFOLGT
codierung_erfolgt
TWO_MICROPHONES
wert_01
TYP_LENKUNG
linkslenker
ACC
nicht_aktiv
WAEHLBARE_SPRACHE_1
us
WAEHLBARE_SPRACHE_2
franzoesisch
WAEHLBARE_SPRACHE_3
spanisch
ADRBOOK
aktiv
WEG_EINHEIT
mls
AEREA_CODE_DVD
wert_01
DWS
aktiv
BMW_N_DEALER
nicht_aktiv
TRF
nicht_aktiv
KANA_WRITER
nicht_aktiv
SMS
nicht_aktiv
WEATHERBAND
aktiv
LEGAL_DISCL
nicht_aktiv
REV_INPUT
aktiv
UNIT_FEET
aktiv
ACOUSTIC
aktiv
TEMPERATUR_EINHEIT
grad_f
ZEIT_EINHEIT
12_stunden
DATUM_EINHEIT
mm_tt_jj
NAVIGATION
aktiv
BACKDOOR
nicht_aktiv
STANDHEIZUNG
nicht_aktiv
cd-player
PHONE_VERSION
most-phone1-1mic
BA_LAENDER_VARIANTE
usa
DEF_DATUM_EINHEIT
mm_tt_jj
DEF_DRUCK_EINHEIT
psi
grad_f
DEF_WEG_EINHEIT
mls
DEF_ZEIT_EINHEIT
12_stunden
JAPAN
nicht_aktiv
MULTIPARTY
nicht_aktiv
NAVIGATION_TYPE
navi_sv
ONLINE
nicht_aktiv
content_enable
ONLINE_DISABLE_VMAX
standard
REVERSE_GONG
nicht_aktiv
SIM
nicht_aktiv
sprecher_weiblich
sprecher_weiblich
sprecher_weiblich
DEF_BALANCE_VOLUME
standard
DEF_BASS_VOLUME
standard
DEF_ENTERTAIN_VOL
standard
DEF_EQUALIZER_VALUE
standard
DEF_FADER_VOLUME
standard
DEF_GAL_VALUE
keine_anhebung
DEF_GONG_VOLUME
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
DEF_JPGONG_VOL
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
DEF_LAST_SPEECH
us
DEF_NAVI_VOLUME
standard
DEF_PDC_VOLUME
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
DEF_REVERB_VALUE
standard
DEF_SEC_VOLUME
standard
DEF_SPEECH_VOLUME
standard
DEF_TEL_VOLUME
standard
DEF_TM_VOLUME
standard
DEF_TREMBLE_VOLUME
standard
GAL_VALUE
keine_anhebung
LAST_BALANCE_VOLUME
standard
LAST_BASS_VOLUME
standard
LAST_ENTERTAIN_VOL
standard
standard
LAST_FADER_VOLUME
standard
LAST_GONG_VOLUME
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
LAST_JPGONG_VOL
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
LAST_PDC_VOLUME
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
LAST_REVERB_VALUE
standard
LAST_SEC_VOLUME
standard
LAST_SPEECH
us
LAST_SPEECH_VOLUME
standard
LAST_TM_VOLUME
standard
LAST_TREMBLE_VOLUME
standard
EINH_MASTER_KOMBI
nicht_aktiv
ONLINE_CALLSTRATEGY
use_csd_paketdata
CRUISE_CTRL_CCC
nicht_aktiv
OIL_LEVEL
aktiv
CBS
cbs_3
CID_CCC
cid_high
CID_COLOUR
table_1
CID_TYPE
static
KLIMA_SG_ART_CCC
high
PDC_SIGNAL
pdc_no
PDC_TYPE
full
PIA
ckm
VA_FLAP_CC
nicht_aktiv
nicht_aktiv
VA_FLAP_HMISTART
nicht_aktiv
VA_FLAP_NAVI
nicht_aktiv
VA_FLAP_PHONE
nicht_aktiv
VA_FLAP_SVS
nicht_aktiv
RDC_CCC
aktiv
AUTO_DRV_LIGHT
nicht_aktiv
C7501_TAGFAHRLICHT
fkt_gesperrt
HDC
nicht_aktiv
RAIN_LIGHT_SENSOR
nicht_aktiv
STANDLUEFTUNG_CCC
aktiv
MDRIVE
nicht_aktiv
MDRIVE_ALBV
nicht_aktiv
MDRIVE_SMG
aktiv
BLUETOOTH_NODES_CCC
profil_2
HUD_M
nicht_aktiv
MAX_PHONE_VOL
standard
e60_stereo
e60_hifi
e60_top_hifi
e61_stereo
e61_hifi
e61_top_hifi
e63_stereo
e63_hifi
e63_top_hifi
e64_stereo
e64_hifi
e64_top_hifi
e87_stereo
e87_hifi
e87_top_hifi
r56_stereo
r56_hifi
e90_stereo
e90_hifi
e90_top_hifi
e91_stereo
e91_hifi
e91_top_hifi
e92_stereo
e92_hifi
e92_top_hifi
MFL_MENU
nicht_aktiv
AUX_CONFIG
mounted
VA_BPI
aktiv
HIP
aktiv
RDS_AF_FUNKTION_CCC
rds_ein_af_aus
MP3_CCC
full
IBOC_CCC
nicht_aktiv
main_or_fullscreen
RVC
nicht_aktiv
RVC_CONNECTED_TO_VM
nicht_aktiv
RVC_DISPLAY_OPTIONS
main_or_fullscreen
TOWBAR
nicht_aktiv
SVS_MICROPHONE_PATH
most
ALLOW_GPS
aktiv
BMW_DEALER_CCC
aktiv
BMW_HOTLINE_CCC
nicht_aktiv
BMW_MOBILE_CCC
aktiv
DAY_RUN_LIGHT_CCC
aktiv
DSC
nicht_aktiv
ROLLER_COVER
nicht_aktiv
ZBE
high
DAB
nicht_aktiv
DAB_BAND_SETTINGS
nicht_aktiv
DAB_FM_SWITCH
nicht_aktiv
REAR_HEAD_UNIT
nicht_aktiv
VA_MP3_DISCLAIMER
nicht_aktiv
FOND_MID
nicht_aktiv
CA_TMC
nicht_aktiv
JAP_SIDEVIEW_CAM
nicht_aktiv
LEGAL_DISCL_TIMOUT
standard
TOP_AMPL_TYPE
logic_7
aktiv
VA_CORNERINGLIGHT
aktiv
VA_FB
nicht_aktiv
VA_FB_COMMUNICATION
nicht_aktiv
VA_FB_ENTERTAINMENT
nicht_aktiv
VA_FB_NAVIGATION
nicht_aktiv
VA_FM_AM_TOGGLE
nicht_aktiv
VA_FOND_CLIMATE
nicht_aktiv
nicht_aktiv
VA_MANUAL_SHIFT
nicht_aktiv
VA_MODE_TOGGLE
nicht_aktiv
nicht_aktiv
VA_SEATVENTILATION
nicht_aktiv
VA_WELCOMELIGHT
aktiv
CAR_COLOR_CHAMP
nicht_aktiv
TELEFON_TYPE_C08
prof_phone
VA_AIRVENT_SHORTCUT
nicht_aktiv
nicht_aktiv
VA_PDC_LOW
nicht_aktiv
aktiv
VA_SEATHEAT_SLIDER
aktiv
DVD_EJECT_LOCKED
free
AUDIO_VOLUME_STEPS
e60_top_hifi
e63_top_hifi
e61_top_hifi
e64_top_hifi
e87_top_hifi
e90_top_hifi
e91_top_hifi
e92_hifi
e92_top_hifi
e70_top_hifi
e71_hifi
e71_top_hifi
e93_top_hifi
e81_top_hifi
e82_hifi
e82_top_hifi
e88_top_hifi
FULLWORD_RECOG
aktiv
CC_LIST
aktiv
DKG
nicht_aktiv
EDC
nicht_aktiv
CBS_STATUS
aktiv
CLIMATE_WO_PREVIEW
nicht_aktiv
NO_DETOUR
nicht_aktiv
ALBV_TOGGLE_APP
nicht_aktiv
BGSCREEN_JUMP
aktiv
DAB_FROM_FM
wert_01
DAB_TO_FM
wert_01
MEDIA_CHAR_ENCODING
iso
MM_DEVICE
nicht_aktiv
MM_DEVICE2
nicht_aktiv
NEXT_SOURCE
nicht_aktiv
OLD_TELEMAT_STRUCT
aktiv
TLC
nicht_aktiv
nicht_aktiv
VA_KANJI_TYPEWRITER
nicht_aktiv
TDA_ASC_STATUS
nicht_aktiv
TDA_BDA_STATUS
nicht_aktiv
TDA_CFG_AUTO_TRIG
nicht_aktiv
aktiv
TDA_CFG_HLC_DATA
nicht_aktiv
file0
aktiv
TDA_CFG_VEHICLE_SER
nicht_aktiv
aktiv
TDA_HLC_STATUS
nicht_aktiv
TDA_MSC_STATUS
nicht_aktiv
TDA_SERVICE_STATUS
nicht_aktiv
TDA_TDC_STATUS
nicht_aktiv
MDRIVE_LOW_CCC
nicht_aktiv
SITZHEIZUNG_APP_9
aktiv
CCC_E71
nicht_aktiv
NAVI_PFEIL
aktiv
TELESERVICE
nicht_aktiv
MDRIVE_MENU
nicht_aktiv
nicht_aktiv
SVR
nicht_aktiv
TV_FRONT_ENABLED
nicht_aktiv
VEHICLE_FINDER
nicht_aktiv
VIDEO_DENY_C0B
deny_slow_key
ONLINE_DAR_TYPE_B
dar_us
VIDEOMODUL_CCC_B
nicht_aktiv
DEF_VERBRAUCH_CCC
mpg
TMC_REGIONAL_C
nicht_aktiv
VERBRAUCH_CCC
mpg
My Ride: 2006 M5
Thanks Sublime!!
I just coded my CAPPL with it and I still have no sound... SMH. I read in another topic that the Fiber Optic output module in the CCC may need to be programmed in order for it to work... Unless I'm missing something...
My Ride: 2006 M5
Update: I've confirmed that I have audio output from the CCC module via the standard stereo wire output. Definitely a programming issue.
My Ride: 2006 M5
Update: Got the audio activated!! Working like a charm
Aside from adding $609, make sure to add $693 & $697 to your FA & FA-Write your CAS & LMA. Programming must be done with the ignition ON motor OFF. Once programmed, Power OFF (remove key) for 5 minutes and allow the system to turn itself OFF. Turn back ON and it should work after this and your programming is done. FYI my system is Logic 7 not "standard".
Cheers!
![Hyper](https://5series.net/forums/images/smilies/imported/hyper.gif)
Cheers!
![Dance](https://5series.net/forums/images/smilies/imported/dance.gif)
My Ride: 2006 M5
