CCC from M5 into standard E60 - NO SOUND - HELP!
Just installed a CCC from a M5 into my E60, everything works apart from there is no Sound.
No sound for anything even door open bell, parking sensors....... Anyone know how to fix? |
Was it a retrofit or a replacement? If it is a replacement, use ncs expert and code the CCC back to defaults with a blank .man or expert profile. Code all five components. If it was a retorfit you may need to update the VO.
