Carputer Install
My Ride: 2005 530d M Sport, Carbon Black, Black half leather
Right.. after having my car for about two months now i been looking at retrofitting alot of things but have finaly decided that putting in a carputer is the way forward! All in one, everything can be added when it needs be
Have been searching on the net and people dont have to many problems with the job but advice would still be great
After looking on this site, heres the things i THINK i need
Mini PC, doesnt HAVE to be designed to be a car-pc but obviously has to be small for install reasons
Screen capable of replacing iDrive screen
Car UPS so when the power cuts out when ignition is turned off it safely shuts down the system
Power transformer of some sort to power the pc.. not to clued up on this yet so will have to research
Carputer Software... this is the least of my worrys
Anyone here done a carputer install
My Ride: G30 M550i
Model Year: 2018
Take a look at the following threads to see some examples of what others have done:
http://forums.e60.net/index.php?showtopic=70725
http://forums.e60.net/index.php?showtopic=...amp;#entry53246
http://forums.e60.net/index.php?showtopic=62371
Yeh i seen all of these after doing a few searchs. so so much reading to be done. very interesting information. I see you have replyed on alot of the carputer topics. They all seem to have problems geting the iDrive signal and the car-pc signal to go into the same screen.. Would be great to just have a button to switch over the signal so if you needed idrive to change any settings its just a push of a button away. I got abit confused with the iBus and MOST talk..
On the first link hes done a great job installing the monitor but i think i would hit the screen everytime you put it into gear, and would also take your eyes well away from the road if you wanted to change anything while cruising along. where as doing the iDrive screen upgrade its dead in front of you and just a small glance away.
I will try put together a little shopping list of prices for like, screen, pc, cables ect and see what can be done.. Im from the UK so things tend to cost that little more!
Does anyone know if anyones solved the problem with having idrive and pc on the same retrofitted screen?
Will keep you all updated as to how i get on if i do take on this project
i used this item and it works fine, i have an e60 2004 530d with no navigation fitted just basic business radio no changer,
the item cost ?299 and comes with tailor made install instructions for e60, all you need to do to activate it is press the menu button under the idrive spinner for a couple of seconds and it switches over as it links into the canbus system, from your car computer you will need an a/v out and some way of getting sound into the headunit???, this item has a fm modulator but this dosnt seem to give a good signal (i think the e60 reception on the fm is crap anyway), if you want i drive back on press the menu button again once, easy and you still keep idrive !!!!,
http://www.pegasussl.co.uk/series-inputs-v...on-p-12344.html
hope this helps
ps i didnt install a computer but gps using the following box with route 66 running and using a remote to input the route settings as i drive screen is not touch screen (works quite well)
http://cgi.ebay.co.uk/Navigationssystem-GPS-Box-Navirechner-Tom-Tom-Route-66_W0QQitemZ250354140281QQcmdZViewItemQQptZTechnik_Auto_Hi_Fi_Navigation_Einbau_Navigationssysteme?hash=item250354140281&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
pps i tapped into the cigarette lighter for switched power although it goes off when the key is not in the start engine position (damn car , cant find a basic switched power wire anywhere!!!)
full gps running on the idrive screen for under ?500
hope this helps
simon
hope this helps
hope this helps
simon
socale39
09-05-2023 08:30 AM
umnitza
06-23-2015 03:41 PM
DetailersDomain
Detailing Forum
05-29-2015 04:52 AM
snaprolll
DIY: Do It Yourself
05-05-2015 05:09 PM
