car wont start
My Ride: 2004 545i — Sapphire Black | Sport | Premium |
Wheels & Suspension — DCR Nurburgring Satin Finish with Chrome Lip 20x9 front 20x10.5 rear | Toyo Tires 245/30/20 front 285/25/20 rear
Performance — In the Works: RPI Exhaust | RPi Ram Air Induction
Exterior — Onex 4300K Fog lights | Stage 3 tint all around | M-Tech kit |
Sounds - Alpine amps | Memphis Audio Front and Rear | Kicker Subwoofer | Stealth Box |
i installed HID on my fogs lights and the computer screen started blinking. steering wheel is locked up and hard to turn. head lights will not turn on. when i fully turn the key car clicks almost like alternator is cranking. please i need help! I have a bmw 545i. i followed directions in installing HID with a capacitor and resistor to block the computer from error messages.
Just off the top of my head, make sure your battery terminals are tight and make sure the battery has enough of a charge before you troubleshoot to the next step.
2. If things do not work properly after returning to stock, check the battery terminals and battery.
Originally Posted by DRANGED' post='819011' date='Mar 17 2009, 03:09 AM
1. Remove the the HID kit and put everything back to stock. When back to stock, try the headlights and try starting the car.
I've actually done that already. it seems after disconnecting the battery the computer became even more non responsive.
Originally Posted by Carlo545I' post='819763' date='Mar 17 2009, 10:38 PM
Hey thanks for all your help. It was actually the battery. It was time to change it out. i have 2004 BMW 545i and i never replaced the battery. Too bad it cost me arm and a leg.
I replaced my e39 battery with one from Auto Zone for like $100
You prob could do the same... you don't hav to get the OEM once
BTW, how did you kn your battery is bad?
From what i was told the battery for the e60 has to be programmed to the computer or it wont charge right. The e60 seems to be more computer based than the e39. maybe you know something different that i dont. But that is good information on your part cause a friend of mine has a e39.
Awest91
09-17-2022 11:05 PM
