A/C issue
My A/C wasn't blowing as cold as I thought it should be seeing how I've felt colder from less quality vehicles. I am an aircraft mechanic and a friend of mine is an experienced auto mechanic and does a/c work. we put a set of gauges on it and the low side was too high indicating a blockage. we replaced the expansion valve and after two cans of Freon the a/c temp was the same but when we put in the third the temperature rose by 10 degrees and the high and low side pressure indications went the opposite directions as they were supposed to. Any ideas on what may be causing this ? Is there something else that would cause a blockage ?
Are you sure you didn't overcharge it? When I re-charged my system (2004 545i) I only put in two cans. If I remember correctly the BMW spec was for just barely over 2 cans.. maybe an ounce or two over. It's probably not quite as hot over here (central NC), but it's in the 90's pretty regularly and it cools the car off fine. I may add the extra few ounces at some point to see if it makes it better.
Putting too much in will cause the temp to go up |
I just replaced my dryer filter and compressor and flushed out my condenser then put in the exact amount specified using a brand new snap on recovery/servicing machine...no change....low side is still too high....guess all that's left into replace the condenser because its still indicating a blockage.
how high?
55 on the low side and like 210 on the high.....its the condensor....did some research this weekend and found that its a parallel flow and non flushable...when blowing thru it with shop air and/or your mouth its obviously plugged up...ordered a new one already...update coming soon
my ac wont get very cold, actually the passenger side seems colder than driver side. Is that possible. What could be the problem
That sounds more like a blend door
agree
Originally Posted by chrisgo
(Post 1517877)
