Are the Brakes made of Gold?
Is the car a daily driver? How long do you plan on keeping it? IMO stick with all OEM parts unless you plan on taking it to the track. Most of the pads that promise less dust, also have less stopping power or "bite". You can turn the factory rotors, but what was explained to me by my local BMW mechanic was that the rotors are a bit softer and once turned can develop small craters under heavy braking over time. This can lead to warping, which you would have to replace your rotors at that time.
I had my front rotors turned, changed my own pads with Textar Centrics, changed the sensor and haven't had any problems since.
*Remember you can't turn cross drilled or slotted rotors, so once they go be prepared to buy new ones.
My Ride: .
Model Year: .
Originally Posted by Texas545i' post='1084213' date='Jan 4 2010, 08:09 PM
If I wanted to do this myself, is there a way I could save on the parts? I can do the work, but if I'm only saving $250, I'll let someone else spend their time doing it.
My Ride: 525
Easy DIY for any shade tree mechanic. Check rotor thickness, they may not need replaceing. Rotors typically last for two sets of pads. And while turning them is always a good idea, if they are very smooth with no ridges, it's not always necessary. I've seen a few shops take off more than was needed.
I do like OEM pads. Plenty of places to get them on-line at reasonable prices. I've had a few bad experienes with brake squeal on a new aftermarket pads (mostly on a volvo), but ever since I've stuck to OEM.
My Ride: Original E60 Spec:
530i - Silver Grey Out, Black Dakota Leather In, Navigation Pro, Voice Command, HiFi Audio, Sports Package, Premium Package, Cold Weather Package w/ Heated Seats, Style# 123 Alloy Track Wheels, Auto AC, Power Front Seats, Active Turn Xennon Headlights,
Mods:
OEM M-Tech Front Bumper, OEM M Side Skirts, OEM M5 Rear Bumper, M5 Trunk Lid Finisher, M5 Style Mirrors, Custom Hamann Style Splitter, Custom Hartge Style Diffuser, RD Sport Boot Spoiler, LCI Taillights, Bruce Miranda's V4 LCI Retro Cables, 6000K Xenon light Bulbs, Xenon White LED License Plate Lights, 8000K HID 9006 Fog Lights, Akalius� Front Headlight Euro Overlays, Matte Black Kidney Grilles, E60.Net Clings, Debadged, Llumar Tinting "Micro Edged, 15% Rear 35% Sides,
Engine Mods:
Custom Magnaflow Quad Exhaust w/ Eisenmann Stamped 3� Tips, RPI Scoop (Red)
Added Electronics:
V1 Equipped (Hardwired), OEM Alpine CD Changer Retrofit,
Shoes:
SOLD-20" Staggered Vertini Hennesey Rims, Falcon 452's Tires-SOLD
New Shoes:
19" VMR 710 Hyper Silver, General Exclaim UHP 245/35/19 Front-275/30/19 Rear, Gloss Silver Caliper Paint Job DIY
^_____________
Retired
______________
Took Delivery 10/26/2009: LOADED! E60 M5 Silverstone II/Black, Active Seats, Comfort Ventilated/Heated Seats, HUD, Brushed Aluminum Trim,
Originally Posted by skeeter' post='1084217' date='Jan 4 2010, 08:13 PM
You can have the stock rotors turned!! Pads are fairly cheap as well....If you have done brakes before you'll be fine!!!!The brakes are the same as any car....You will just have to buy a new sensor for the front pads...Sensors are about $15...Pads should be around $100....Turning rotors are about $7 each rotor...I bet you could get out for around $150!!
My Ride: Mini Cooper
Originally Posted by 08white' post='1084215' date='Jan 5 2010, 10:12 AM
get aftermarket rotor and break pads, you can get solid or slotted rotor if you want, but not drilled, unless you get bramboo $$$
I had them for over 1 year and they are fine.
they were Zimmermann
Originally Posted by nonm5e60' post='1085086' date='Jan 6 2010, 03:26 PM
i just got my brakes changed on my 525i
brembo rotors from Murray's $467(tax included)
axxiss(pbr) dustless brake pads $170
labor $100 per axle + brake sensors
total $767
total $767
umnitza
11-03-2015 02:58 PM
PelicanParts.com
07-16-2015 01:12 PM
