Brake Fluid Flush
Old Mar 8, 2005 | 03:16 PM
widjajachandra's Avatar
My Ride: Jap Snail with 4 bangers
Does Anyone know how to do it?
I looked around the brake caliper but I did not find the plug.
Thank you in advance.
Old Mar 8, 2005 | 03:41 PM
Guest
Guest
Posts: n/a
[snapback]98776[/snapback]
I doubt that anyone in this forum will help you out because I tried the similar question regarding to the replacement of the brake rotor in E60. No answer at all. This is not a technical/mechanical forum for the DIY mechanic.
Ching-Ho Cheng
Old Mar 8, 2005 | 03:45 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
I'd tell you if I'd know it. But that's something I let the dealer take care of. Sorry.
Old Mar 8, 2005 | 06:25 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Guest' date='Mar 8 2005, 07:41 PM
I doubt that anyone in this forum will help you out because I tried the similar question regarding to the replacement of the brake rotor in E60.? No answer at all.? This is not a technical/mechanical forum for the DIY mechanic.?
Ching-Ho Cheng
[snapback]98783[/snapback]
Ching-Ho, if you read many of the threads, you'll clearly see that this forum has plenty of technical/mechanical information -- although I can't possibly read every post (I leave that job to Iceman) and I don't remember ever seeing your request for info on the rotor replacement so all I can say is sorry I missed it. If you can, bump it up or post a link to it and I'll see if I can help you out.
widjajachandra, the following document is an overview (more details available if needed) and I must say that after looking at the overview, I think that the fluid replacement task should be left to the dealer!
Good luck...
RA__Bleeding_brake_system_with_DSC.pdf
Old Mar 8, 2005 | 08:05 PM
Hey that's awesome .
Unfortunately I do not have much guts to do it by myself
But I did it already before I read your message for my M3.
What I did was I opened the valve and pressed the brake pedal a couple times and I add the new brake fluid.
Does Valvoline sysnthetic brake fluid have low-viscosity?
Is it ok for what I did already?
Do I need to go to dealer to get the fluid replaced for my M3 because I did stupid thing?
I'm confious now :'(
Old Mar 8, 2005 | 08:55 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
What year M3 do you have (E designation would help too)?
Old Mar 8, 2005 | 09:23 PM
[snapback]98944[/snapback]
I have 04 model.
Old Mar 9, 2005 | 05:16 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
You might have done a stupid thing, I'm not sure. If I understand what you did correctly, you might have induced some air into the system.
Here is the TIS document that explains how to bleed the brakes on an E46 M3:
E46_M3_Bleeding_brake_system_with_DSC3.pdf
Hope that helps.
Old Mar 9, 2005 | 06:45 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by Rudy' date='Mar 8 2005, 10:25 PM
[quote name='Guest' date='Mar 8 2005, 07:41 PM']I doubt that anyone in this forum will help you out because I tried the similar question regarding to the replacement of the brake rotor in E60.? No answer at all.? This is not a technical/mechanical forum for the DIY mechanic.?
Ching-Ho Cheng
Good luck...
Attachment 5580
[snapback]98883[/snapback]
[/quote]
Rudy,
Thanks for your information. My post is still in this forum and still no reply. Reader in this forum just read the post.
Here is the post which I put out back in 1/11/05 : http://forums.e60.net/index.php?showtopic=6258
Thanks,
Ching-Ho Cheng
Old Mar 9, 2005 | 06:54 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I looked last night and found some extensive instructions. I'm heading to South Florida today so once I arrive and have a few minutes, I'll compile all the documents and post it. If you don't see anything in a day or so, feel free to remind me...
