BMW N63 How to replace turbocharger coolant pump
⚙️The reason I am replacing it is due high noise from the pump, and not building presssure enough to recirculate the coolant through the turbos, and creating knocking in the hoses, due to boiling coolant around the turbos.
In this video below 👇👇👇 I will be showing you how to replace your turbocharger coolant pump on N63.
jallerd
01-24-2014 06:37 AM
