5Series.net - Forums
-   DIY: Do It Yourself (https://5series.net/forums/diy-do-yourself-14/)
-   -   BMW coding (programming) unlock all doors (https://5series.net/forums/diy-do-yourself-14/bmw-coding-programming-unlock-all-doors-152175/)
KKDriver Dec 28, 2021 10:47 AM
Hi all. I want to share my experience with BMW coding. I have used scan tool Launch X431. Unlock all doors when car stops and turn off the engine” In order to code that option you need to access CAS module of your BMW and change it to ”enable” You can also change your preference if you whant the windows to be closed automatically when lock the car. Or long press the lock button of your key to close all the car windows. If you have any questions or help just leave a comment below and I will answer as soon as I can. Please see the video below 👇:
