5Series.net - Forums
-   DIY: Do It Yourself (https://5series.net/forums/diy-do-yourself-14/)
-   -   Battery Replacement Experience (https://5series.net/forums/diy-do-yourself-14/battery-replacement-experience-143301/)
E61FUN Oct 25, 2015 09:25 PM
Please delete thread.
JayArras Oct 26, 2015 04:01 AM
Thank you for the excellent write-up and photos! :twoup: I moved your post to the DIY section where I think more people will benefit from it.
One question though, why did you select the Exide Edge AGM FP-AGML5/49 over the others? :question:
JayArras Oct 27, 2015 03:35 AM
Originally Posted by E61FUN (Post 1570366)
Batteries Plus Bulbs had the cheapest price and didn't require a core charge or the return of my old battery. So the old battery went to a lead recycler that paid a nice core charge.
In Connecticut, retailers don't require a core charge, but give you $5 - $10 off the price of the battery if you give them your old one. How much does one get from a lead recycler if they were to bring the old battery to them themselves?
txag_530i Nov 6, 2015 06:26 AM
Originally Posted by E61FUN (Post 1570302)
I chose to add in wiring for a little DieHard 3amp trickle charger. The images below depict Rev1 wiring. Rev2 wiring will use a different plug style, larger gauge cable and eyelets, which will allow for better jumping from compact LiON battery packs. I wonder that low battery jumping is better accomplished out front in the engine compartment, nearer the starter motor. While trickle charging could be done from either end, the losses when hooking up in front and pushing trickle current all the way back to the battery slows the charging process, in my experience.
The potential for an explosion from any battery gases is admittedly quite small, but is a risk nonetheless. It is therefore not a good idea to jump or charge the battery at the battery terminals. Charge or jump the battery from the engine bay.
mayanktanwar Sep 14, 2016 08:48 PM
Battery Replacement
Last month i replaced battery of my BMW 5 SERIES 520I, EXIDE MTDIN100 from BatteryBhai.com online. Their experts technition replaced it smoothly and they carry service battery also. First they installed service battery then replaced it. I asked them why they installed service battery, they told me service battery is installed because electronic system of my car remain same and i loss nothing. I'm quite impressed of using their technique for replacement of battery.
