Anyone interested in an N62 Secondary Air Hose DIY?
My Ride: 545i - GONE
BMW part: 1913968
I tackled this job over the weekend, but didnt have anyone nearby to document what had to be done. This hose splits into two ends, which go to both sides of the engine, right underneath the intake manifold. Sometimes this hose will crack, and you'll get a vacuum leak.
Job does not require removing fan, or anything related to coolant. I did have to remove the factory strut bar, cabin boxes, intake, put hood in service mode, and climbed all over the engine. If you've ever changed the spark plugs on an N62, then you can definitely handle this job.
If anyone local needs this done, I can help and you can document what needs to removed and put back together.
Catch me around San Jose, CA.
I should clarify, I had a mechanic replace most seals, gaskets, valley pan+gasket, spark plug tubes, all other crap you should normally do before this. I ordered the secondary vacuum hose after the mechanic did all the work, sorry!
-- ck
-- ck
Going back for installation, make sure you go over one of the smaller coolant lines, and make sure the intake manifold doesnt sit on this line when you place it back on. It'd be best to connect the two ends into the valves before you connect the main end in the front of the engine. This is because its harder to clip in (mines at least) if you connected the front end first. It'd be a good idea to tape everything off and label them.
I did not hear a hissing noise from the hoses, figured I'd replace them since this is a common issue. On top of that, my car is running lean, there's got to be a vacuum leak somewhere.
My Ride: 545i sport
I dont think it is a good idea to remove or un-seat the intake manifold and then NOT replace the seals. My advice is if the intake manifold seals are disturbed in any way, then they should be replaced.
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
I am thinking of removing the intake and replacing the coolant pipe under the valley pan but wondering how involving it is to remove intake. What are the other parts to replace once it is off except the gaskets and vacuum tube. I gonna to do the valve cover gaskets at the same time.
