any one have a LSD on their E60 or fitted one?
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
looking in to a Lsd for my car who has one and who has fitted one
looks like its a bit hard to find one any one know any ideas if any internals can be used from another diff
i used to have a E30 Bmw before you could use various bmw diff parts
also has any one had theres welded
yes i am got Dunlop brand tyres and still loose a bit traction on zooming off from a stand still and some time in kick down while driving
i want to make use of the power rather than loose it i got a Ac Snitzer diesel upgrade still to fit which will add more power to the car
i have had E30s bmws before with a lsd the car transforms and you get much better handling even taking corners hard i back off as i can feel it might slide out from the back on the e60
i can feel i loose alot of power when the traction light comes on and one or the other wheel spins
im sure we can use internals from another lsd as with the E30 bmw you could use Z3 E36 ones and E28 ones
No it improves it
If you have a lsd and have traction on and you launch off from standstill the light wont blink as the lsd passes all the power to both wheels rather than one spins this is when the traction light starts flashing this lowers the power to the wheels it waits until the wheel spin has stopped or has been controlled make is a big difference which is a open diff is what we have
If you have two e60s one with and with out a lsd and do the above you will see major difference search lsd videos on youtube will show how good they are
bestofthebest
03-30-2015 08:12 PM
