Activate RTTi
Old 10-08-2011, 08:11 PM
  #31
infin8's Avatar
My Ride: BMW 550i M Sport
Model Year: 2010
Engine: 4.8L V8
Originally Posted by rictor
Once I get my feet wet sure. It may be a few months though... baby on the way and lots to do!
Congratulations! I understand perfectly, I have a baby on the way also. Ours is due April 17th. When is yours coming? I appreciate your willingness to help me out with the coding. Do you already have the cord and whatever else is needed? If not, maybe we could just split the cost of everything we need to code both cars. Take your time though, I'm in no rush...there are definitely higher priorities right now. A couple or 3 months sounds cool. Btw...what part of the valley are you in? I'm in Central Phx., but we are seriously considering moving before the baby comes. Love the house we're in now, but hate the neighborhood. Let me know and thanks for lookin out for a fellow member.
Nate
Old 10-11-2011, 03:03 PM
  #32
rictor's Avatar
Congratulations to you too! Mine is due December 22nd so we're nearing crunch time. Painting nuseries and what not... When I could be working on my car! Anyway, I don't have the cable or anything yet. I'm also wondering after snooping around BMW Coding if I should get a battery tender to ensure power to the car? I'm not sure if it's entirely necessary... It will take me a little while to get everything together. I have some suspension work to do as well so it all depends on priority. I live in north Peoria. I'll let you know.
Old 10-11-2011, 03:52 PM
  #33
vkhong's Avatar
Model Year: 2010
Definitely use a battery tender during coding. I always charge a vehicle at 4 amps for about 10 minutes before I start coding. During this 10 minutes, I set up the laptop, read and rename / save the trace files. These saved trace files make it easy to reverse changes in the event of operator error, or if the module shows unexpected behaviour / paramaters after coding. The battery tender stays on during coding. Also ensure that the laptop computer has a fresh charge, good batteries and preferably on AC power during coding. Last thing one needs is for the vehicle power or laptop power to fail during coding or programming. Such interruption could leave a module in an unresponsive state, requiring a replacement module.
Old 10-11-2011, 06:26 PM
  #34
AchtungE60's Avatar
My Ride: E60 530i
Or a messed up cable like the first two I bought. LOL damn chinese copies. After Screwing something up and putting my tail between my legs at the dealer I bought a good cable... a bit more but definitely paid for itself on first use anyway.
Old 10-16-2011, 03:06 AM
  #35
fov001's Avatar
My Ride: 525i M54 2005 Alpine White Sport/Cold/Premiun Sound/Active Steering Navigation/PDC/sport seats/6 CD Changer
I have a 2004 530i with CCC, FM radio with RDS, no HD, no Sirius.
I have the newer CCC software (silver background).
ISTA/P 40.3, upgraded on Feb 18. 2011
The RTTi activation worked for me.
CID / I-Drive Display shows "TI"
Navigation map view:
- Traffic icons on map
- Map options -> Route Preference -> Dynamic Route
- Map options -> Traffic Info
Navigation menu also includes Traffic Info, after Address Book, Information.
Found these pictures online...
(select for details)
Blastiwi gave me access to the Google Docs spreadsheet. I can get to it, but still only view-only mode.
BMW RTTi FAQ
Do I need to upgrade my CCC to do this? I have 2005 525i with 2011 Nav software but my CCC is the original build.
Thanks!
Old 10-17-2011, 08:04 AM
  #36
locomotiveBart's Avatar
You shouldnt need to update, unless your car has the very old original idrive software. The easiest way to tell if it will work is to pull the trc file and see if the parameters are present.
Old 10-17-2011, 09:03 AM
  #37
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
I don't think this is necessary at all unless you're doing some serious updates via WinKFP, etc. I have coded upwards 40+ cars and never hooked up to a battery tender. Some cars I have spent as long as 30 minutes and it's always been fine. The one exception was Jasper's car, but his battery was wonky to start anyway, so that don't really count.
Old 10-17-2011, 08:12 PM
  #38
Sublime's Avatar
My Ride: 2012 535i M-Sport
lol @ wonky. I thought I was among the last to use that word.
But yeah - using a battery tender is overkill for coding. I've even gone as far as coding with my engine running with zero issues so far (knocks on wood). From what I know about WinKFP, it will fail the flash deliberately if the voltage falls outside what it considers to be safe parameters. Scary stuff.
Old 10-17-2011, 08:17 PM
  #39
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Hehe. Yah, I actually have code with the engine on as well. Kind of discovered that it was okay by accident. However, I am still a bit cautious of doing that with certain modules though. Figure I shouldn't push my luck, hahaha.
Old 10-17-2011, 11:31 PM
  #40
BLooD's Avatar
TMC_REGIONAL_C
Dont work on UK E60`s, I tried it on mine and I lost TMC all together.
Quick Reply: Activate RTTi
