AC basic to AC high retrofit DIY rev.3
Blood so if i resume the retrofit it's should be like this :
1/ connector X1527 (26pin blue)
from X18793 (original black 18pin) -------to X1527 (new blue 26pin)
1 -------to 1
3 -------to 9
4 -------to 8
6 -------to 6
7 -------to 7
8 -------to 21
11 -------to 15
12 -------to 16
13 -------to 18
14 -------to 19
15 -------to 20
16 -------to 14
2/ connector X13765 (power and ground):
from X18793 to X13765
10 -------to 1 (red)
18 -------to 2 (brown)
(we need to add 6 inch of red and brown cable to each)
3/ connector X01130 (12pin black) :
nothing change in this connrector, it's stay as original
4/ solar sensor : (we add/connect 4 cable from the X1527 to the solar sensor)
from X1527 (blue 26pin) to Sensor
10 -------to 1
13 -------to 2
11 -------to 3
12 -------to 4
not used at all from X18793 :
2 not used
5 not used
9 not used
17 not used
can you pls just confirm me that it's the correct way.
thanks in advance
1 -------to 1
3 -------to 9
4 -------to 8
6 -------to 6
7 -------to 7
8 -------to 21
11 -------to 15
12 -------to 16
13 -------to 18
14 -------to 19
15 -------to 20
16 -------to 14
10 -------to 1
13 -------to 2
11 -------to 3
12 -------to 4
2 not used
5 not used
9 not used
17 not used
thanks in advance
from X18793 to X1527
1 to 1
3 to 9
4 to 8
6 to 6
7 to 7
8 to 21
11 to 15
12 to 16
13 to 18
14 to 19
15 to 20
16 to 14
10 to 1 (red)
18 to 2 (brown)
from X1527 to Sensor
10 to 1
13 to 2
11 to 3
12 to 4
2 not used
5 not used
9 not used
17 not used
thanks in advance
1 to 1
3 to 9
4 to 8
6 to 6
7 to 7
8 to 21
11 to 15
12 to 16
13 to 18
14 to 19
15 to 20
16 to 14
10 to 1 (red)
18 to 2 (brown)
10 to 1
13 to 2
11 to 3
12 to 4
2 not used
5 not used
9 not used
17 not used
thanks in advance
1 -------to 1
3 -------to 9
4 -------to 8
6 -------to 6
7 -------to 7
8 -------to 21
11 -------to 15
12 -------to 16
13 -------to 18
14 -------to 19
15 -------to 20
16 -------to 14
10 -------to 1
13 -------to 2
11 -------to 3
12 -------to 4
2 not used
5 not used
9 not used
17 not used
1 -------to 1
3 -------to 9
4 -------to 8
6 -------to 6
7 -------to 7
8 -------to 21
11 -------to 15
12 -------to 16
13 -------to 18
14 -------to 19
15 -------to 20
16 -------to 14
10 -------to 1
13 -------to 2
11 -------to 3
12 -------to 4
2 not used
5 not used
9 not used
17 not used
pin 21 of the blue plug and cut the wire leaving enough on both ends, take the wire sticking out of the loom and run a cable from it to the ground (brown) wire in the two pin plug then add a length of cable to the wire attached to pin 21 and fix that to the power wire (red) on the two pin plug.
correct ?
where are you getting the wiring plugs/connectors from ? direct from bmw ? and do they have them in stock or do you have to order them first .
also what about the condensation sensor ? as there doesnt seem to be anywhere to mount it behind the screen in the mirror housing.
one thing i have noticed is that the lci with high ihka doesnt have a solar sensor mounted on the dash board ,confirmed this on my brothers 2008 model .
Pin 21 (Airco Compressor) from the Blue connector should indeed be cut and routed to the 2 pins connector for the power for LCI AC Panels.
BLood, this is for the pré-LCI model, if i do it for the LCI model, i have to change :
correct ?
correct ?
