545i oil drain plug
OK. I did the searches and read info and watched the video for the oil change on a 530.
I just got under my car (04.545i) and removed what appeared to be the plastic cover where the oil drain plug should be. The interior contents do not look anything like the picture posted for the 530 (naturally, different engines, right?).
Does anyone have pics of the drain plug location and drain plug that they can post here?
Thanks in advance.
Mark
Thanks in advance.
Mark
Found a PDF on this engine. The Gallery seems like an odd place to retrieve DIY based information. I suspect it's due to the file nature of PDFs fitting into a picture gallery? Maybe we can make a pointer from the DIY to the gallery?
Figures the 545i doesn't have as elegant of a setup as the 530...
Strange -- the oil filter drain plug seems like it's made of rubber/plastic. Must be my imagination....
Mark
Mark
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
Mark
Mark
Originally Posted by luigi524td' post='566129' date='Apr 22 2008, 07:30 PM
Your oil drain plug will not be rubber / plastic. Start here to get an idea off what you should be looking for: http://www.realoem.com/bmw/showparts.do?mo...hg=11&fg=10
I think I got it resolved. The rubber/plastic I was referring to is the 'nut like' top structure of the oil filter housing. I see now that in the center of that area there is a drain plug for the filter housing.
Mark
My Ride: 2005 545i, Non-Sport. Nav, Logic7
I'm getting ready to change my oil for the first time and I've never seen a non-housed filter like this one. I've never owned a BMW, so I'm used to the typical American car oil filters. Is there anything specail I should know/do before I change the oil on my 05 545i? Is there a certain process or procedure that will save me some headache? I looked a the link in this thread and I never saw the filter. I'm assuming it goes on that long stick with the O-ring above it. Am I right?
My Ride: 2004 525i, Metalic Gray, Premium Package
Originally Posted by markke' post='566149' date='Apr 22 2008, 06:05 PM
Thanks, Luigi.
Mark
Mark
Why do you need to touch the oil filter drain plug? I have a 2004 525i, and I am thinking to do oil change soon. I thought I just need to replace the filter, and unscrew the oil drain plug to let the old oil out. I don't quite understand what oil filter draing plug does and why we need to touch it. Maybe you are taking about oil drain plug at the underside of the car?
My Ride: 545i Sport
Engine: N62
Originally Posted by BlueHorse' post='636859' date='Jul 31 2008, 12:13 PM
Hey, Mark,
Why do you need to touch the oil filter drain plug? I have a 2004 525i, and I am thinking to do oil change soon. I thought I just need to replace the filter, and unscrew the oil drain plug to let the old oil out. I don't quite understand what oil filter drain plug does and why we need to touch it. Maybe you are taking about oil drain plug at the underside of the car?
After draining the oil through the drain plug, I just unscrewed the filter housing and changed filter. The filter drain plug is to drain oil in the filter housing prior to removal to avoid spill. Don't forget to change the copper washer on the drain plug. Replace the big rubber O-ring on the filter cover (plastic). The leftover smaller O-ring is for the filter cover drain plug(metal)
![](http://www.autohausaz.com/secure/PartImages/11427511161.jpg)
Originally Posted by Rizbel' post='637316' date='Jul 31 2008, 10:14 PM
+1. Didn't bother with the oil filter drain.
Are both of the two small o-rings for the oil filter drain plug, or one of them is actually for the oil filter cap? Is this right that I only need to replace the large o-ring?
Thanks.
My Ride: 545i Sport
Engine: N62
Originally Posted by BlueHorse' post='637320' date='Jul 31 2008, 10:21 PM
I just bought an oil filter from Pepboys for my 2004 525i. I am surprised that instead of 3 o-rings in the picture here, the package only contains 1 o-ring - it is the largest one. The other two small o-rings in this picture are not in the package I bought.
Thanks.
Thanks.
![](http://www.jefffenley.com/covergasket.jpg)
My Ride: 545i Sport
Engine: N62
Thanks.
Thanks.
Good luck
