545 Oil Change Question
My Ride: E60 530i
Engine: M54
Originally Posted by Spaceroach' post='546870' date='Mar 18 2008, 09:59 AM
One more question - i noticed in the BMW 545 oil change PDF that the "Tightening torque" for the drain plug is 11 13 1AZ.
I understand foot pounds or newton-metres, but what does 11 13 1AZ mean?
And do most of you use a torque wrench on these plugs?
Thanks!
Thanks!
My Ride: 2013 M5 - Sakhir Orange / Black Leather.
Originally Posted by lcc014' post='546871' date='Mar 18 2008, 10:05 AM
I really have no idea of this 11 13 1AZ, but what I do all the times is to hand tighten first then use the wrench to tighten the drain nut a bit more. That's it. Do not over tighten the drain nut .....
I beleive the 11 13 1AZ is a reference to the tightening torque table on the last page of the technical bulletin. Take a look.
Also, when I first changed the oil on my 550 (at 1,500 miles), I noticed the following. The oil pan is apparently painted at the factory with the drain plug and copper washer installed. Therefore, when I took the drain plug out of the oil pan for the first time, the copper washer appeared to be part of the drain plug becuase they were "painted together". I had to snap the copper washer off the plug.
In other words, there is most certainly a copper washer on the drain plug when the car comes from the factory. It's just difficult to discern it from the plug itself becuase it has been painted black like the plug and they are stuck together. If you don't remove the original one that has been "painted on" the plug, you will have two of them. Probably not a good idea.
socale39
09-05-2023 08:30 AM
mantraguy
03-09-2015 02:56 AM
Don Juan
03-11-2004 03:14 PM
