545 Oil Change Question
Hey i just changed the oil in my 04 545, and even though tightened the drain plug screw on the sump very tight, i am still leaking a little bit of oil.
My question is: Are you supposed to have an o-ring or washer between the sump and drain screw?
Thanks in advance!
Thanks in advance!
My Ride: E60 530i
Engine: M54
Thanks in advance!
Thanks in advance!
My 08 didn't come w/ it, but the kit includes the washer so I installed it anyways since it wouldn't hurt.
Thanks in advance!
Thanks in advance!
My Ride: E60 530i
Engine: M54
Originally Posted by Spaceroach' post='546376' date='Mar 17 2008, 02:07 PM
ok thats what i thought, thanks. so put the washer on the screw then the rubber 0-ring, correct?
yes, rubber o-ring goes on the filter, which you'll see when your remove the filter - just to be clear.
ok sounds good and thanks for the info.
Looks like i will be changing the oil again. i don't think i will be able to take the screw out, put the washer on and rescrew it in without losing all my oil hehe.
My Ride: 2008 535i w/ Sports & Permium Pkg. Silv/Blk
2008 VW R32 w/Nav.
1992 VW Corrado Silv/Blk-retired
2001 530i Sports/Premium-retired
well I ended up draining the oil into my extra large pan and putting the copper washer on the screw.
Then i put the oil back in the car. it was only a day old and i didnt want to waste 70 bucks worth of BMW synth oil.
The leak is gone!
Thanks for the tips all!
The leak is gone!
One more question - i noticed in the BMW 545 oil change PDF that the "Tightening torque" for the drain plug is 11 13 1AZ.
I understand foot pounds or newton-metres, but what does 11 13 1AZ mean?
And do most of you use a torque wrench on these plugs?
Thanks!
Thanks!
