530xi - air filter (not cabin filter) queries
Hi,
New to DIY and have some basic - probably dumb - queries on the air-filter (not cabin filter) replacement on my 2006 530xi.
I used this thread as a reference but still request some guidance: https://5series.net/forums/topic/101...xi-air-filter/
1. Am I right that the orange filter, which is easily removable, is the air-filter to be replaced?
2. I ordered a K&N filter from Autohaus (part # 13717521033KN). Is this fine?
https://www.autohausaz.com/search/pr...=13717521033KN
3. If yes to the above, two issues I face when I tried their rust-red filter:
(a) puzzled that its height is less than half of the existing filter. As a result, the K&N is not fitting smug and can slip down towards the bottom because of the space. Is that ok?
(b) when I attempt to close the air box, the lid does not sit properly and I am forced to push it down slightly hard to fasten the metal clasps back. (That wasn't the case with the original filter.) Is that fine?
Would appreciate any feedback.
Thanks!
Thanks!
My Ride: 2004 545i 6 speed, Silver Gray A08, Gray leather
Mods: Hard-Wired Passport 9500ix LIVE , K&N Air + RPi Scoop, Mtech V2.1 AE, ACS pedals+Ebrake, flip up front plate, OEM 172's, Custom M Kit, M3 shift knob, Eisemann Race Exhaust
2005 X5 3.0 (the nightmare)
1998 528i SOLD @ 173K
1.) Yes
2.) According to their site its right. http://www.knfilters.com/search/appl...x?Prod=33-2292
A. Filter should fit in the groves in the factory air box. if it falls inside its the wrong filter.
B. If the lid does not seat properly it's not the right filter. It should fit tight but not be forceful.
Check the box it came in and see what part number is on it. Check the link I provided.
Upload some pictures if you can.
Thank you for the feedback. Much appreciated.
Yes, K&N filter box specifes that part # is 33-2292.
On 3a: The K&N filter height is certainly less than half of the original yellow one; the top dimensions are nearly the same and as a result, the k&n seems to fit right for most part but a corner or sometimes a small portion of the side slides does slide down slightly.
To be clear, it is not dropping or falling down in total; at the same time, it is not fitting in smug like the original did.
3b. Lid is now fitting proper; I realized only this morning that I hadn't inserted the bottom portions properly in their slots. Once I fixed that, I was able to juggle the lid to close in tight; clasps are now fastned without any issue.![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Will try to load some pics later today.
Thanks again!!
Thanks again!!
My Ride: 2007 525xi led ae's, magnaflow exhaust, k&n filter, carbon filter delete, 19" BBS LM-R. Sprint booster, black tails, euro fresh headlight decals.
it looks to me like the bottom of the filter, the portion we cant see well in the picture isnt properly in place. pull it up slightly to seat it in properly. hope you get it!
Car has a distinctive smooth response.
Thanks for the feedback.
PelicanParts.com
07-23-2015 12:41 PM
