530 Spark plug change
I'm coming up on 100K miles and want to change my plugs. I've searched for a DIY but could not find one - does anyone have instructions or insight on the procedure? Any recommendations on replacement plugs?
My Ride: 2005 530i, Orient Blue, M-tech Front, otherwise stock.
I just changed mine out last week following some rough directions I had seen on the forum. Just search for spark plug change and you can use the directions for the other models as a reference. I think I had followed the N52 engine directions, I have a 2005 530i. In hindsight now, I feel that I could do the job in an hour or less. I took some pictures while doing the change, I'll try to find time to post them up with a detailed DIY, possibly tomorrow. I skipped out on taking pictures of a few steps, but it was more of the minor steps and I've seen pictures on the forum to cover those.
As far as plugs, you can go to BMW and they should be around $20 a plug. I purchased mine from www.pelicanparts.com for $11.75 a piece and you would need 6. They offer free shiping with a $75+ purchase, I just purchased an oil filter while I was at it, but if you haven't changed your microfilters, you can order those because they must be taken out when you do the spark plug change anyway. You can use either the NGK or Bosch spark plugs, Bosch is what was standard in my car.
I tried to be as detailed as possible with my photos, and I'll try to be just as detailed with my explanation. Again, I'll try to post it all up tomorrow evening, I should have time then. I also replied to your PM, check it out.
i would assume it's similar to this (with less plugs): http://forums.e60.net/index.php?act=attach...st&id=47957 (550 instructions)
Sorry, still haven't had time to post it up. I just uploaded the pictures last night and sorted through them. Been busy with real work
I tried posting the DIY up on here, but I guess photobucket images aren't allowed. I'll have to find out what works on this forum for hosting pictures. What do you guys use?
Anyway, I have two options to view the write up I did. One is if you PM your email, I can send you a word document that has everything typed out, but the pictures are all linked so you have to click the link to view the pictures. The second option is to go to this site and see it, I'm not sure if it will display properly though, but we'll see. Sorry again, I typed this up really quickly.
2005 530i Spark Plug Change DIY
Thanks!
~Lawrence
Thanks!
~Lawrence
Thanks!
~Lawrence
Thanks!
~Lawrence
Originally Posted by EV4530' post='772197' date='Jan 19 2009, 09:59 PM
Thank you Lawrence, I wish I would have seen your diy when I did mine but at least I know I did it right now that I saw your diy.
