2006 E60 Coolant Hose Connector Dripping
I had to change out the coolant hose that goes from connecting with two bolts on the front top of the motor to the thermostat.
Here is the hose. Only pic I could find online.
http://cowtownwakepark.com/wp-conten...6/bmwhose1.jpg
Here is the hose installed.
http://cowtownwakepark.com/wp-conten...6/bmwhose2.jpg
I must be missing something but if the bolts are both on top how does the bottom part of the hose make a seal and not leak. Both bolts are tight and I have a slow drip when the engine is running. Just makes no sense to me how that hose seals up???
Need help Please!
Need help Please!
My Ride: 05 545i 6MT
Make sure the oring is not cut when you install it back. Use sylglide from Napa (sylicone grease) to slide the oring in.
More than likely you have a cut oring.
Need help Please!
Need help Please!
kane1111
04-10-2015 04:40 PM
BYS2
03-30-2015 05:33 AM
